I cannot get normal sound from my secondary speakers on my kenwood sound system. The main speaker or subwoofer is fine, but all of the secondary speakers only make a loud noise when you turn them up, but no normal sound. tabwyn
    President:
  • 2,777 Answers
Wasn't I speaking with you earlier on this one? So now you have no audio whatsoever? Just "noise" from the speakers? Did you get the volume adjusted? Or am I thinking of someone else..?
Thanks
Tim
Posted on Jul 19, 2009
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have a velodyne sub woofer needs amp power source I have a kenwood eq and a sony reciever trying to figure out how to hook it all up right
So, you don't have a powered Velodyne sub (with a built in amp?)
Without model numbers - I"ll guess that there are speaker in and out connections on the back of the sub.
You simply connect the left and right speaker wires from the receivers to the subwoofers input speaker wire connections.
Then connect your main speakers from the sub's Out (or "speaker"} connections so that the sub is in line with the speaker path.
Use the sub's crossover settings on the back till you hca a seamless blend of the sub to the speakers where it is hard to tell you have a sub other than you your music now has deeper bass.
Why do you need the Kenwood EQ? This is not a necessary piece as nobody really knows how to use it properly and it realy complicates how you use your system. Flashing lights look cool though, right?
If you really must complicate the operation of your system then connect the Tape output of your receiver to the tape input of the Kenwood EQ, Then connect the Tape output of the Kenwood EQ to the Tape input of your receiver - assuming your receiver even has tape ins and outs.
You can engage the Kenwood EQ by inserting it into the audio path when you select the appropriate Tape input as the source on your receiver.
Hope this helps.
May 31, 2014 | Audio Players & Recorders
I have a Kenwood KFC-XW1100DVC sub woofer and it sounds blown.it was working fine when i took it out of my jeep.I put it back in and it worked fine for 5 minutes the started crackling.
If you're sure that you didn't drop the subwoofer while handling it outside of your Jeep, make sure your connections are solid. Perhaps you did not connect your wires from your terminal to the voice coils solidly. Otherwise, use your best judgement and determine whether or not the subwoofer is up to par on its normal performance. Try to keep the volume down for a little bit, to give it some rest.
Mar 01, 2011 | Kenwood KFC-XW1100DVC Car Subwoofer
What kind speaker use my kenwood powered subwoofer 103SW
It uses a 10 inch, 4 ohm speaker, probably rated at 100 watts. If you are getting no sound, check your connections. Or, the subwoofer amp may be blown.
Aug 29, 2010 | Kenwood 103SW Speaker
Recomended amplifier for tr 2800
I've had a set of TR-2800s for about 7 years, I started with a kenwood stereo amp but graduated to a Yamaha 5.1 system in 2008, any system with 100 watts or better output on the main channels is fine, You can't blow these things without 400 or more watts.
Aug 03, 2010 | Theater Research TR-2800 Main / Stereo...
I just moved my 12" kenwoods to a new car. i'm running a 760watt amp with 6 guage wire. last week they sounded crystal clear, no rattle or anything. but this week they have a constant loud rumble,...
It sounds like you have a feedback problem between your amp and your speakers this is usually caused by a bad or weak ground between the amp and chassis ground and speakers and chassis groung, also make sure that the correct post on the speakers is the one attached to ground as this makes a big differance especially with high power systems. Hope This Helps Don
Dec 02, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
I want to upgrade my Kenwood KDC-MP435U sound
1. your charging system is your only limitation for watts but you can add plenty without upgrading it. i'd say 1,000 watts max on the stock batter and alternator with large power and ground cables of at least 4 gauge.
2. yes. using your subwoofer rca outputs.
3. for a subwoofer you should always ad an amp. i'd say a 3-400 watt amp is fine to match up with you kenwood speakers. you will need a small sub to fit in there or maybe one slim enclosure behind each seat with slim 8" subs
Jan 03, 2009 | Kenwood KDC-MP435U CD Player
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
21 people viewed this question
 Grubhead
Grubhead
