Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Battery wont stay charged
Have to jump or charge battery frequently .replaced battery 3x fixed 1 short mower has 120 hrs on it 26 hp kholer command lt 1050
  • Donnie Wilson
    Donnie Wilson May 11, 2010
    does your have a external regulater?it will look like a squar box bulit in to the flywheel cover with wires going to it?
    Problem Solver:
  • 12 Answers
HAVE YOU CHECKED THE CHARGING SYSTEM? YOU COULD HAVE A BAD VOLTAGE REGULATOR. ITS REAL SIMPLE TO DO.START THE MOWER,PUT IT AT FULL THROTTLE.TURN A MULTI-METER TO VOLTS AND TOUCH THE BATTERY.YOU SHOULD READ 13.5-14.6 VOLTS.IF NOT GOOD CHANCE THE VOLTAGE REGULATOR IS NO GOOD.
Posted on Jul 29, 2009
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a sears lawn tractor with a Kholer courage 20 HP. Engine just clicks with the key is turned. Took the battery to have tested and was told the battery is good. But, the tractor will start if I jump...
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
Mar 08, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Runs fine but battery is dead
it should charge the battery itself ,if you have rnn the engine even for a few seconds without abattery connected you will have burnt out the rectifier under the fly wheel, that will probabley be your main trouble
Aug 15, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Volt meter shows 26 volts(2 12 volt in series) but wont run lawn mower. jumped 12 volt car battery and this runs mower at slow speed. is battery dead
Sounds as if battery has internal short. Also have charging system checked. If doing yourself check amperage also. Charging volts and no amps wont work or overcharging. Over charging will ruin a new battery. Also make sure you have clean solid connections between cable ends and battery. Take cables off and clean very good poor contacts will give false readings when checking system.
Jun 27, 2009 | Panasonic LC-X1220P - UPS battery - 1 x...
Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
Jun 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
WILL NOT CHARGE /CRAFTMAN LT 1000 17.5 OHV
You can jump off a off truck ,just dont have the truck running the
altnator can be to strong for the diodes in the tractors charging system (rectiforer).
Feb 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
743 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
