Question about Brother Sewing Machines
I have a Brother XL2030. Light and LCD readout quit working. I replaced the bulb (checked with tester first). Neither still work, help?
I have had to replace light bulb three times in 3 days
Try to find an LED version of the bulb to replace this one. It'll run cooler, take less energy and will last a lot longer
Oct 14, 2014 | Brother Sewing Machines
Free sewing machine manuals
try contacting brother customer service about a manual
Jan 04, 2014 | Brother Sewing Machines
Replaceing an exploded light bulb
cut a potato in half and press the flat spot into the remains of the bulb, and turn carefully
Jun 16, 2013 | Brother LS-2125 Mechanical Sewing Machine
Machine stopped working after bulb fried
it sounds like it's an electrical problem or fuse. you can check with
brother customer service to see if the sewing machine has a hidden
fuse.
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Suddenly LS-2000 stopped working, just a month back we bought it. Even the bulb is not glowing, please someone help me with this..
Take it back to the store, get a replacement. If it is under warranty you don't want to be futzing about inside. Just go get another one.
Oct 14, 2012 | Brother Sewing Machines
Ihave a brothers PC-7500 and the screen is dark
When your Brother PC 7500 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the Brother PC 7500 LCD screen, or buy a new machine.Brother no longer stock this item direct, but there is an affordable replacement available.
Check this Link
May 29, 2010 | Brother Sewing Machines
Changing light bulb on Memory Craft 8000
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Feb 05, 2010 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
168 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
