Question about Dometic Rooftop RV Air Conditioner
My Duo therm fan come on but when try with cool it's shut off the fuse and if turn the fuse back on would come on for a little while and then off again what shuld I do?
  • Dometic Master
  • 6,674 Answers
First thing to check is incoming voltage. If problem with incoming hydro, either from improper cord attached, or whatever that would cause low voltage to unit, that could be the cause, so if you have a meter, try to check that voltage to your RV is up to spec. Let me know
Posted on Jul 19, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
Have A Duo-Therm air conditioner on top of my motorhome and it stoped cooling, the fan works fine. Is there a fuse in the box under the filter? It says there is on the out side. I am not sure where it...
Can you please reply with model number off bottom of upper (roof) unit. Should be able to see it when filter is removed from ceiling assy. Please include model of thermostat if possible. You say fan works, but when turned to cool, no compressor kicking in? Try shutting unit off, and turn off breaker at panel as well, give it a few minutes and retry and see if anything changes and let me know.
Aug 16, 2011 | Dometic Rooftop RV Air Conditioner
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
69 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
