This is a very common problem with the fridge you are having. Do remember the fridge section is only a empty box and the cooling is coming from the freezer section by a fan through a hole covered by a slid . So make sure your setting on both controls are set at the middle point . That is the start.
Then you've to check the timer, then the defrost element, and the defrost thermostat. After all these checking you'll find out why then. Hope this help, God Bless
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the
freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the
refrigerator from main power outlet for 4 hours then reconnect it and check, if
the same problem is noticed again,. If yes then its defrost board problem. The
defrost board located in the back of fridge section. You can get required parts
from www.repairclinic.com or from online sears part site. ------------- Thank
you.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Dometic RM 2310
This is a very small RV freezer/fridge unit
AC/propane 2 way unit
Dometic RM2310
Need model number .
