Question about Vicence Rectangular Watch
The stem of my Vicence watch seems to be broken as the hands still move after I push the stem in. Can this be easily and inexpensively repaired?
  • 65 Answers
Doesn't sound like the stem is broken. Sounds more like the the setting lever is in the wrong position. If this is the case it's easily fixed and shouldn't cost too much.
Posted on Jul 22, 2009
    Problem Solver:
  • 5 Answers
Water-resistant? Around $40
305.767.8886 Florida
Posted on Dec 03, 2015
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
The minute and hour hands are "out of sync"... the
The problem that you describe--misalignment of the hour and minute hands--would be fixed in the way you'd describe--the watch movement would be removed from the case, and the hands would be removed from their pinions and placed down more accurately. This is a relatively minor repair if you have the right tools, but it's not something I recommend for the average DIY person.
The first challenge is removing the watch movement from the case. Some movements drop out easily, but others are kept in place by the crown and setting stem. These must be removed in a way that they can be re-inserted. Simply pulling them out by brute force usually damages the internal set lever; different movements have different mechanisms for releasing the stem.
The second challenge is removing the hands. Attempting to "slide" the hands on their pinions runs a high risk of damaging the pinions by making one or both of them oval instead of round. Very little force is applied to the pinions, so even a slight distortion can mean that your watch will start to hang up at odd times when friction is stronger than the force being put out by the watch movement. Even worse, it's possible to break one of these little parts--they're very strong, but they're also very brittle. A tool called, naturally enough, a "hand remover" is used to pull the hands straight up off their gears; they're then pushed back into their correct place.
For a qualified watchmaker or watch repair technician, this is a simple and inexpensive repair that should take them only a few minutes once they get around to actually paying attention to your watch. Given the high risk of damage to your watch if you haven't done this before and if you don't have a hand removal tool, I would suggest that you outsource this repair instead of attempting it yourself. I have ruined more than a few watches in the course of practicing this repair; it doesn't take much force to damage these delicate parts!
May 26, 2011 | Lucien Piccard 26024 Wrist Watch
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
The sweep hands don't align back to zero after replacing battery
Pull out the stem to the second position then push the chronograph start/stop button a few times to move the minute hand to the zero position. Then pull the stem out to the 3rd position and adjust the second hand again by pushing the start/stop (top) button to move it to the zero position. Once you get them both to top zero push the stem back all the way and screw it in tight. Tim
Jun 21, 2010 | Watches
Watch literally came completely apart..I'm told that the stem broke inside the watch and it's not repairable..IS that true? I paid more for this watch than any othe watch I have ever purchased and it...
If there is any damage to the mechanism, then it is best sent back to the maker. It seems strange that the watch has broken after such short service; if you tell them your story they may look kindly on any repair charges.
I suggest you go to their web site and contact them about your problem http://www.vicence.it/vicence-watches.html
May 01, 2010 | Vicence Rectangular Case Strap Watch
I've recently found an old Elgin pocketwatch (Hunter Case, 1904?)
If you wish to return this watch to a working condition you need to find a skilled watch repairer who is willing to take on a challenge.
It could prove to be very expensive is parts have to be made to replace anything that is worn out or broken.
Jan 05, 2010 | Elgin Circa 1904 Watch
I have a 14 k Vicence gold watch. The battery
SORRY but FIXYA has no idea who made it or where they are , might be out of business .
Oct 19, 2017 | Vicence Rectangular Watch
Stem is broken on the watch
take it to a jeweler, but if u have another stem and crown remove the back and look for a small arrow pointing at a how. push down to release remaining parts and then insert the new one
Oct 07, 2009 | Vicence Watches
Watch Repair-Vicence 14K Milor Italy
Go to a watch repair shop..Its real 14k gold how could it not be worth getting fixed. A jeweler its not a watch repair person.
Apr 11, 2009 | Watches
VicencE Gold Ldies Watch
Try this link - nobody seems to claim to specialise in Vicence but I am sure you can find one to suit. Most jewellers deal with most brands. http://www.yell.com/ucs/UcsSearchAction.do?scrambleSeed=33030598&keywords=watch+repair+vicence&companyName=&location=LONDON&search=SEARCH&searchType=advance Hope this helps :)
Feb 12, 2007 | Vicence Rectangular Watch
Vicence Rectangular Watch Logo
140 people viewed this question
Top Vicence Watches Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Bill Boyd
Are you a Vicence Watch Expert? Answer questions, earn points and help others
