Question about Canon imageRUNNER 2200
Can not print to image runner C3100 over AIX network
I can not print to C3100 over aix network. I can ping the printer from aix server, can print on windows side, when I send a print job to printer through AIX , no output and no entry on error log. i can bring down the queue in AIX , then send a print job, the print job shows in "lpstat ",, then I bring up the queue, nothing prints and no error log. I have identical printer connected locally, no problems. No packets being filtered by routers. Traceroute --- no problems, Test MTU's -- no problem
  • Anonymous Mar 21, 2014
    I'm trying to connect my 5250 to a synology 213+ NAS either as a network printer or locally as a multi function device. The NAS finds the device and correctly identifies it but but I cannot print to it either test print or from an ipad. any ideas?
After further review, the printers in question are setup with UFR drivers, NOT PCL5 drivers like our order stated. Mr Guest , thank you , I do believe you lead me to the answer. YOU ROCK!!
Posted on Nov 26, 2007
This may be a dumb question what print driver are you using? ufr ps pcl. and is it loaded on the copier ?
Posted on Nov 22, 2007
How to enable printer to print when told not to
Setup the printer and connect to PC/Mac using the USB cable.
Power on the printer and OS must identify and install automatically.
If not add printer in control panel (if windows)
If Linux or AIX follow instructions from manual
Mar 31, 2016 | Computers & Internet
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :-
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from to then you want an IP address below
Dec 16, 2009 | Canon imageRunner C3100 Copier
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
How can I mount an IBM AIX hard drive in Windows?
AIX uses a file system that is not supported by Microsoft Windows. Most likely you will need another AIX system to read the file system. I recommend that you contact a hard drive recovery service like Ontrack Data Recovery and get some guidance.
You should remove it from the Windows computer ASAP. Windows has the habit of making changes to any disk it sees and you may lose everything!
I hope this helps.
Jul 17, 2009 | Microsoft Windows Server Standard 2003 for...
Procedure to install ibm aix operating system
Which OS installed tell me then i ll try to solve
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
Can I install Windows Server on IBM RS/6000 51A Server ?
No. The IBM has a RISC processor and Windows only supports Intel or AMD. It does support some versions of linux if you want a GUI interface. :-)
Jan 14, 2009 | IBM RS/6000 9.1GB DASD FEATURE
Cannon Image Runner c3170U
I am not sure what a AS/400 is, but I do know what chip they are asking about. It is called a Network boot Rom. It is like allowing the copier to be a printer. If you look in service mode under display version. It will have a "N" for networking and "C" for a stand alone copier- no printing. Also, some of the new copier come with it and have other options like faxing. Also, are you buying a new one or used? Also, are you going to use it alot? You may want to go with the c4080 or the faster model c5850 copies a minute. Take from me I work on all of them and the c3170c is not a work horse.
Sep 24, 2008 | Canon imageRUNNER C3170U Color Copier
Canon imageRUNNER 2200 Logo
378 people viewed this question
old marine
old marine
