Would like to know where the reset button is serviced engine will pull start but wont start with the key
    Genius:
  • 1,689 Answers
Hi smith
what is the device you are reporting?
your question was about t projection TV but you mentioned something about an engine being serviced?
Posted on Jul 19, 2009
Truck wont fire up antie theft wont let it how do I reset so it will start
Car Won't Start ' The Family Handyman
www.familyhandyman.com > Skills
If you turn the car key and your car won't start, don't give up. ... Symptom: No click when you turn the key; Symptom: Engine cranks but won't fire up ... the transmission range selector (also known as the neutral safety switch). ... That afternoon, the wife and I went to the mechanic's parking lot, where I pushed the reset button.
What to do when your car won't start - Allpar
www.allpar.com/fix/nostart.html
What to do when your car won't start: for fuel injected and carbureted cars ... made directly to the engine block, to prevent a spark near the battery which may explode if ...A perfectly running, recently tuned car died and would not restart. ... To find the neutralsafety switch, look for a small wire attached to your starter solenoid ...
Here's How You Diagnose An Engine That Won't Start
jalopnik.com/heres-how-you-diagnose-an-engine-that-wont-start...
JalopnikJul 16, 2015 - Every truly bad day begins with a car that won't start. ... spark plug boots easily, you can use an inductive tool that lights up when it ... So, how do we check if our fuel pump is getting power? .... There are many other potential culprits, like a neutral safety switch that's .... We are working to restore service. <
Ford F-150 Questions - Won't start - CarGurus
Jan 03, 2016 | Cars & Trucks
How do I reset service now alert in Volks Wagen Golf Engine No. BFQ 164449
1. Keys out of ignition- press and hold in trip odometer reset button "0.0" on right hand side of display
2. Still holding this button down, insert key into ignition and put to the on position without starting the car.
3. Display will read "service now"
4. let go of the "0.0" button and depress the "m" button on the left hand side of the display. this will re-set the service reminder. There is no confirmation on the display other than the words "service now" will disappear.
You can confirm that the service reminder has been reset, or check how many miles/days remain until service at any time by taking key out of the ignition and holding in the trip reset "0.0" button for between 3 and 5 seconds. The MFD will display miles and hours until next service.
http://forums.vwvortex.com/showthread.php?2457779-reset-service-indicator
Nov 03, 2014 | 2005 Volkswagen Golf
How do I turn off the "maintenance needed" light on my dashboard?
This procedure is suppose to be done buy a service tech that has changed you engine's oil. If they have forgotten and you want to reset the light, then it is acceptable. The procedure is easy. Step one:(with the key out of the ignition) gently press and hold in the mileage reset button. Step two: (Still holding the button in) slide the ignition key into the ignition and turn the key to the run position (do not start the engine) Step: wait 10seconds and you will see the "Maintenance Light" go out. Now let the button go. Step five: turn the ignition key back to off and the Maintenance Needed light is now reset. I hope that helps, let me know, good luck.
Mar 16, 2014 | 2003 Honda CR-V
How to turn of change engine oil light on 2011 ford focus
From FocusFanatics online - -
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
Jul 07, 2012 | Ford Cars & Trucks
I have a spanner symbol on my 407. what does this mean??
You need to carry out the periodical car service due (e.g. engine oil & filter, air filter, fuel filter, cabin air filter). The "service" spanner symbol "reset" button is placed on the lower right corner of the dashboard. See picture below:
Then you should reset the "service" spanner symbol by pressing on the "reset" button on dashboard, when ignition key is in OFF position. Hold the button pressed and turn ignition key in ON position. Hold the button pressed and see on the dashboard successive numbers will appear: "10", "9", "8", ... , "1", "0". Then release the button and switch OFF the ignition key. The "service" spanner symbol followed by "20000 km" (or "30000 km" depending of the engine type), will appear for few seconds after turning ignition key in ON position, and will dissapear after engine starting. The car service due was reseted.
Please do rate my response. Thanks!
Feb 21, 2011 | 2005 Peugeot 405
My engine light is on, the brake light comes on and the speedometer stops when that happens, my key is stuck in the ignition, and the blinking arrow won't stop blinking. I am a first time volvo owner. I...
Brake light comes on auto each time you start the car (saftey check) and will go off when you press brake pedal.
Blinking arrow will stop when you click seat belt together (driver)
turn ign off press key in towards drive stem and turn anti clock (5degs)and pull out
Put in key hold in mileage reset button and turn key to on (dont start the car )the last click before starting (and keep finger on miles reset button till flashing stops
then turn off ,this resets all service lights,
tc
Oct 02, 2010 | 2000 Volvo S70
I have a 2008 corolla. It has an auto light when the car needs an oil change. I need to know how to reset it.
Look in your owners manual and go to the part that explains the different symbols on your dash. Look for that service reminder and it should tell you what page to go to to learn more about that. Somewhere there should be some wording to the effect that "When you have your car serviced by a certified Toyota dealer they will reset it for you. In the event that someone other does your maintenance then this is the procedure to reset......."
Oct 04, 2009 | 1998 Toyota Corolla
How do I turn off service engine light on 1988 volvo 740 gle
One way that always works is to disconnect the battery for at least ten minutes. If the cause of the check engine light turning on in the first place is not fixed, then the light will come on again pretty quickly after starting the car.
To reset your service light here are the steps.
1. Get in your car and shut the door.
2. Put your key in the ignition
3. Turn your ignition key to position 1
4. Push in your Odometer reset button and hold it in while holding it move the ignition key to position 2 while holding down the odometer reset button.
5. After couple of seconds of holding the button down and the key in position 2 your service light will start to blink once that happens let go of the reset button and start the car.
Sep 24, 2009 | 1988 Volvo 740
Car wont start. computer says its the anti theft device
is their a button you have to push be4 starting the car?
Jun 19, 2009 | 2001 Chevrolet Malibu
2007 Volvo S80 V8 Sedan Service reset light
Install remote/key into socket.  Push and hold trip button on instrument cluster with all doors shut.  Push start button one time for key position one while holding trip button and count to five.  keep holding trip button and hit start button to key position two where all the warning lites come on the instrument cluster while still holding trip button.  Count to around ten and triangular warning lite should flash. Release button and remove key and then start engine.  May take a few attempts to reset this lite.
Mar 30, 2009 | 2007 Volvo S80 V8 Sedan
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
