Question about Protron PD-800 DVD Player
Connecting protron dvd to dish TV
I have a protron 800 dvd w/ no manual I'm trying to connect the dvd to a RCA TV ;We have Dish network and there is not a converter box; so I need to connect the DVD player directly to the TV. TV is a regular TV about 10 years old. any help is appreciated
thanks
Mona
    Novelist:
  • 85 Answers
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Posted on Jul 19, 2009
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
Feb 06, 2011 | Westinghouse SK-32H240S Television
I have dish network and dont know what channel to go to in order to use my dvd player. I cant find my manual.
Hi my nameis Mike Houston of DISH Network and I was going over your post and see you wantto watch a DVD and not sure what channel or input the TV should be on. Whilewatching a DVD the connectors may be RCA cables (Red, Yellow, White), if those arethe connections you will want to put the TV on either Video1 or Input1. Whilethe DISH Network should be connected to the TV by Coax cable (it will have ascrew on connection). The TV channel should be set to ch3 or ch4, if you haveany questions please e-mail me at michael.houston@dishnetwork.com.
Dec 01, 2010 | Sansui DTV2760 27" TV
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Connect with dish network
Hi my nameis Mike Houston of DISH Network and I see you want to connect your ProtronPD-DVR100 DVD to the DISH Network receiver. To connect you player to the DISHreceiver and depending on the receiver you have there are different ways toconnect the two. I will send a link to help with these steps and if you haveany questions or concerns please e-mail me at michael.houston@dishnetwork.com;http://www.dishnetwork.com/SupportSection/manuals. - Mike H.
Jun 27, 2010 | Protron PD-DVR100 DVD Recorder
How to hook up dvd to tv through dish network box
I do hope that you have gotten this resolved, but if not, here are some steps.
From the receiver box:
You will want to connect RCA (red/white/yellow) from the TV1 slot to the IN on the back of the DVD. You can also use coax, which would then be connected to TV SET OUT on the back of the receiver.
From the DVD:
You will want to have more RCAs going from OUT on the DVD to the TV. Then the TV needs to be on channel 3 or 4, and on an input. Usually Video 1 or 2. The DVD will need to be on whenever you are watching the DISH.
Becki Barned
Jun 26, 2010 | Vizio L32 32 in. LCD HDTV
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
1998 Older TV, Dish Network and DVD Player I can't set up
try getting an rf modulator, they are about 20 bucks at walmart, i had to do that for my dad, his tv had the hookups but it still wouldn't work. try that you might be able to hook up the dvd, tv, and dish network plugs all in one.
Mar 08, 2009 | Protron PD-007 DVD Player
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PD-800 DVD Player Logo
222 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
