Question about Wacom Intuos3 12x19
Water damage kid spit water stop working after aweek
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 231 Answers
This solution has worked on many water damaged goods in the past. try placing the item in a large ziplock bag filled with dry rice. give this several days to obsorb the moisture then try to function it.
Posted on Jul 24, 2009
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
Spitting sputtering
Your water solenoid is sticking. It is drawing air back through it when off then the pressure of the water is keeping it open. I would replace the solenoid valve.
Apr 14, 2014 | Amana Refrigerators
Why is oil spitting out of the vent cap?
s there a leaking internal seal and its overfull drain it and look for water if so look for a damaged seal
Mar 25, 2012 | Garden
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
I bought a razor from a friend who just got a blackberry, I put my sim in and it worked fine for aweek. Then a couple of days ago it just stopped everything when I turn it on and press any key it says Wait...
This is caused by a bad flex cable. More specifically the upper ear flex. It has malfunctioned (mostly due to water damage) and keeps recording memo notes (as if you are pushing the side button). This can be serviced easily. Usually $30-$45
Mar 10, 2009 | Motorola Mobility RAZR V3
Philips Azur 4200 Iron spits out water like a water gun, burning my hand when ironing
i think you will find the solution is an easy one...you could wear some overalls and protective work wear....or.....stick some blue tack over the hole.....or .....get your husband to do it.
Nov 03, 2008 | Irons
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like you have an intermittent problem with the board or one of the on board switches.
Oct 22, 2007 | Maytag MAH6500 Neptune Front Loading...
Open Questions:
Wacom Intuos3 12x19 Logo
390 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
