Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher
Problem for Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher
Water enters dishwasher, soap door opens but soap
By robertshroad on Jul 19, 2009
Water enters dishwasher(new water line and valve installed, soap door opens but soap just runs down the door. Dishes remain dirty.
Solution #1
posted on Jul 19, 2009
Somewhat Helpful)
drallim
Rank: Guru
Rating: 87%, 757 votes
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 24 in. JDB1080AWS
Questions and Unsolved Problems for Jenn-Air 24 in. JDB1080AWS
Do you recommend Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher?
Answer
Answer
I have a JennAir model JDB5900AWN that just started to not drain out the final rinse water prior to... (More)
Answer
Water comes in water goes out but while in does not get dispersed Arm does not move. I'm guessing... (More)
Answer
The only button that is responding is the "Quick Wash" button. This has happened before... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
