Question about HP Computers & Internet
Problem charging my laptop. I have to wiggle and trick it to charge it.
  • 2,567 Answers
Seems that either the power socket in the laptop has a loose connection, or the battery terminals are not having good contact with the metal prongs connecting it to the laptop charging circuitry.
A quick check to see if the power socket has a loose connection is to remove the battery & power the laptop only from the adapter. If the laptop works from the adapter without having to be wiggled, then the problem is not with the power socket. Instead, it is the battery contacts. Try to clean the contacts using a non-oily contact cleaner & see if this resolves the problem.
Posted on Jul 19, 2009
Battery will charge but connection of charger has to be just right to connect and then cannot touch it. will wiggle around
If you are sure that you have to wiggle your laptop charger to let your laptop charge normally, it means your hp laptop power jack is loose or dead. Either you need to replace it or fix it.
While if you are good at tech and you have a good knowledge of laptop, you may fix the power socket by yourself based on the following instructions article:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Jan 16, 2013 | HP Pavilion Computers & Internet
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
I am having charging problems, i can wiggle the cord and it will charge if I hold my thumb on it. I ordered a new cord and that didnt help at all
Ordering a new power adapter is not the solution, this is a common problem with all laptops.
The power connector that we wiggle actually shakes the power connector on the motherboard of the laptop and slowly disengages it from the motherboard hence it does not charge the battery under normal conditions. During initial stages wiggling the cable works, but later when the metal contacts go bad we are in trouble.
The actual solution to this is to replace the motherboard of the laptop or you can contact a local technician who can open your laptop and re-solder the power connector or connect a new power connector socket to your motherboard and solder it.
Dec 10, 2010 | Acer TravelMate 2300 Notebook
Laptop will not charge. After wiggling the cord
That's a short in the power input section of the motherboard- I've found, much to my dismay, that the power input/charging circuit on these laptops is not a separate circuit board as it is on some other models, but is a small area of the motherboard itself. You'll either need to have someone repair the motherboard or replace it entirely.
www.dfwsupergeek.com
Feb 16, 2010 | Gateway MT6705 Notebook
My power cord is loose. It plugs in and charges,
Hello !
If I'm understanding you correctly, the wiggle is from the laptop. Sounds like a problem is about to happen. Your Presario has a loose power jack (connector inside the laptop). It is a part that can be replaced.
If you need further info, let us know.
Hope this helps.
Oct 23, 2009 | Compaq Presario CQ60-220US PC Laptop
My inspiron 1525 is not charging. Have replaced battery and charging lead and still does not charge.
Based on what you have stated, you replaced the battery and charging lead but the laptop still won't charge. What do you mean by charging lead?
Are you referring to the power adapter?
Since you already changed those two things, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
MY DELL VOSTRO 1500 PROBLEMS
The DC power jack on the laptop may be worn out and needs to be replaced. Does it begin charging if you wiggle the power jack a bit?
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
