Question about Hitachi 43UWX10B 43" Rear Projection Television
Wont Power on Light Flashs
I see others have posted on the same issue, Im curious, I realize that a fuse must be blown, I have several green lights and one red light, how do I diagnose where the problem is???
  • 1,694 Answers
Re: Wont Power on Light Flashs
Check for shorted cap C702 and open fuse E994.....Let me know..............I will research when I go in to my shop this morning...............................T.
Posted on Dec 17, 2007
0 characters
3 Points
While watching a movie on my RCA tv. model #HD52w59, it just lost all power and wont turn back on and the green power light does not light up. there is powere at the putlet so i know its something with the...
check first loose or broken power cord. if ok, what you can do is look for the power supply board look for blown fuse sometimes due to voltage fluctuation the fuse get blow.
Sep 17, 2012 | RCA Projection Televisions
Mitsubishi DLP 52525 contant green blinking light
This could be a problem with any of the capacitors....from the power supply to the FMT board. If you have the means to do so, I would check them all. But at the end of the day, even if you fix it, you are still going to have a MIT DLP POS. LOL! Sorry....Hope this helps, Chad
Oct 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Projection Televisions
I have a WS-55511 rear projection TV. We had a power outage in the area and the TV will not power at all. Could this be a blown fuse?
if the green power light just blinks that is one issue==========if the green power light does not come on at all suspect a fuse----follow the power cord (set unplugged) into the set and plug in ac fuse is right there.
If you have the blinking light that will not stop it means the DM unit in the set was damaged and that is expensive.
If you need more information or have questions let me know with a comment here.
Sep 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
TV wont turn on
hi there, well my friend, this rear projector tv has 3 lenses, one that projects red light, one green light and one blue light. the liquid came from those lenses and it helps the light go tru the space. each one has a sensor and if theres not fluid the tv will protect itself and wont turn on.
i'm not to sure if the fluid made any short circuit between components, because is an oily solution and don't have many conductor properties. (correct me if im wrong) but i suggest if you don't have electronic knowledge or skills, don't attempt to repair it yourself, its hard even for experts to remove all the connectors and will take several time to do it.
Dec 11, 2008 | Sony KP-61HS10 61" Rear Projection...
Sanyo Plasma Tv
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
May 05, 2008 | Projection Televisions
Hitachi 60UX58B Comes on then goes back off.....
Yes, i just answered a post to another problem simular to this, it is the POWER SUPPLY, it was blown either from an electric surge, caused by storms or ground faults, or it was shorted. you need to get a new one, have a professional install it for you.
Apr 22, 2008 | Hitachi 60UX58B 60" Rear Projection...
61HX70 61in. terribly distorted picture blinking red power light
Convergence amp ic bad
Or send to
good luck
please mark the post with a fixya
Oct 22, 2007 | Toshiba 61HX70 61" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
47 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
