Home | Westinghouse | LVM-37w1 37 in. HDTV-Ready LCD Television | Westinghouse LVM-37w1
Westinghouse LVM-37w1 37 in. HDTV-Ready LCD Television
Problem for Westinghouse LVM-37w1 37 in. HDTV-Ready LCD Television
By twinnell on Nov 19, 2007
Screen suddenly goes black and the speaker pops. No picture, no sound. But the blue light stays on and does not turn amber. Cable box hooked up using components. DVD hooked up using components. I have unhooked one component at a time and this occurs for both dvd player and cable box.
Same Problem
May 04, 2009
-   Problem is the same. I think it may be the power supply. shopjimmy.com does not list any power supplies for LVM-37W1 only LVM-37W3. Are these equivalent -   mtaplc
Mar 17, 2009
-   Screen shuts off and the blue light stays on. -   Guest
Dec 02, 2008
-   I tried fixing this problem with a replacement power supply I bought on ebay for $130. Easy enough to do--just take out a bunch of screws and then swap the part out. It worked for a couple hours and then it was history again. Save the $ and buy a new TV.
-   cmvu
Nov 06, 2008
-   I have the same problem. At first after turning it on it would run fine for 30 minutes and then the screen would go off but the audio would keep going.
I wrote a blog post about my LCD issues.
-   Dugdale
Nov 03, 2008
-   I started having the same problem but thought is was directv hd receiver and contacted them they sent a new one,got the new one did the same thing.I have a new computer hooked up with tv tuner and was watching football game and it did the same thing.Black screen blue light still on.In my case turn it off and back on and it works, it does this usually when you first turn it on 1,2,3,4 times then it usaully stops doing it.So I did a search on google and found all of you,I have a 4 year extended warrantee threw best buy. I bought it in 2006 and till now havent had any problems.Time to call best buy!-   gta1987
Solution #1
posted on Dec 17, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue, and I have read about 1 more of thse I wonder if they have a issue where they all break this time of year :-) I WILL NEVER BUY A WESTINGHOUSE AGAIN
Solution #2
posted on Oct 22, 2008
Very Helpful)
EE Prof
Rank: Apprentice
Rating: 100%, 2 votes
I have had this problem since about superbowl time. If I powered the set off, waited 15-20 seconds, and then powered on, it would work again for a while. Repeating this drill a number of times would lead to stable operation. We resorted to a course of turning on some XM music from DirecTV when we weren't watching. I tried a technician knowledgeable on this set, and it would have cost $500-800 to repair the set. We learned from different forums that the likely culprit was either the power supply board or the LCD controller. We also picked up the rumor that Westinghouse had quit making replacement part. It would seem that the management of this organization has a death wish. TO THE CHASE: shopjimmy.com is now selling parts from canibalized sets. They have a non-DOA warranty and a good return policy. A power supply from "Jimmy" solved my problem. I have one important hint: To remove the back, take out the obvious screws and the base. Then remove the ~5/8" rods that protrude from the bottom. There is a screw up inside each rod.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Sep 14, 2009
Not Rated)
dnelson502
Rank: Apprentice
Rating: 0%, 0 votes
new westinghouse part telephone number 562 236 9800 cost is 59.95
Was this helpful?
Yes
No
Solution #4
posted on Jul 27, 2009
Not Rated)
laudio
Rank: Apprentice
Rating: 0%, 0 votes
From the service tech at Audio-VideoSales-Service LLC
Westinghouse Model # LVM-37w1
Problem : comes on and goes off
The inverter board is bad, but it can be fixed.
cost w/labor and tax about $230.00
Was this helpful?
Yes
No
Solution #5
posted on Jun 28, 2009
Not Rated)
smcclung
Rank: Apprentice
Rating: 0%, 0 votes
Aloha everyone,
Add one more to the list of victims of the WestingLouse company. Bought this POS monitor in 2006. Paid for extended warranty. Pop goes the screen. After you screw around turning it on and off it eventually won't come on again at all. It is the Power supply board. It can be removed with a screwdriver and a lot of time. Called Best Buy and they said they had no record of my warranty (of course). They are not making power supply boards for this model anymore. You can get one through ebay if you're lucky (or maybe not so). These are canabalized from old monitors and therefore are a "Pop" away from failing themselves. Remeber their guarantee is no DOA. So in a week or month you will be stareing at that blank screen again. This beast has been sitting around my livingroom for months. Can you spell CLASS ACTION? Westinghouse - Never again!
Was this helpful?
Yes
No
Solution #6
posted on Sep 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Westinghouse is the worst TV on earth, I hated the quality from day one, and now the above mentioned problem (exactly like mine) is ruining our tv experience. POS,
NEVER BUY WESTINGHOUSE !
Solution #7
posted on Aug 08, 2008
Not Rated)
Dave_Techie
Rank: Apprentice
Power supply issue. Unlike many of you I (thought) I had purchase a 2 year extended warranty. I purchased this in June 2007. In June 2008 the set died with the exact symptoms described here and elswhere. The extreme short version of this is that westinghoue refuses to hep however did admit, sort of, that (And this is a driect quote from them to me) "There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions." They also said they provide part to anyone via their dub sidstriboutors. However yesterday, August 7, I was informed Westinghouse no longer provides power supllies for this therefore it can not be fixed.
As for the bait and switch warranty I purchased - it is a long story but short version is upon purchase it caid if anything went wrong it was covered 100%. If it coulod ne be fixed it owuld be replaced - 100%. It also said that if it needed to be shipped all cost woyld be covered 100%. So here I am with a monitor sitting in a repair shop that will not be returned to me uless I PICK IT UP because service.net will not pay for it to be returned. I will not get a replacement set but am getting a "buy out" offer of about 570.00 I can use for anything I want. Within one minute of being told it could not be repaired I purchased the power supply myself however unless I get my Monitor back that may be another waste of money.
So solution to everyone at this point is - 1> Fix it yourself 2> Try to find a legal team who does class action lawsuits and file against Westinghouse for putting out units with faulty power supllies that now can not be fixed because they no longer make the power supllies 3> sit back and get reamed again by compnaies who think we won't fight back. I am alsready fighting back at least to the repir shop who is holding my monitor hostage and Service.net who is selling scam warranties.
Was this helpful?
Yes
No
Solution #8
posted on Nov 20, 2007
Not Rated)
loumargo
Rank: Wiz
Rating: 80%, 22 votes
It may be that your control module is bad
your tv has to be checked out by an ex[erienced teck
Lou Margo
Allied Electronics
loumargo@verizon.net
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LVM-37w1 37 in.
Questions and Unsolved Problems for Westinghouse LVM-37w1 37 in.
Do you recommend Westinghouse LVM-37w1 37 in. HDTV-Ready LCD Television?
Answer
Answer
I have the westinghouse monitor ( modeL # lvm-37w1) nad the picture keeps going nuts on the left... (More)
Answer
lvm-37w1 . sound works but picture is completely scrambled. The screen has horizontal lines moving... (More)
Answer
Tv turns on for a split second then picture dissappeares. The power light stays on
Answer
my westinghouse 20'1 lcd monitor shutts off whithin 3 seconds after i turn it on.??
Answer
color on screen is fine then goes to a green haze and returns to fine again
15 Other Users Have The Same Problem - Continued
Comment by dbroncs3053, posted on Oct 21, 2008
This first happened to me right after I had programmed a new Harmony remote to control the tv. The screen goes black, then after about the 3rd or 4th time of powering the tv back on it will stay on. I was wondering if this happened to anybody else after programming a universal remote to operate their tv or if mine just happens to be a coincidence?
Comment by tomsnead33, posted on Oct 20, 2008
Exact same problem. BB said this was the Main Control Board ( 5600110382) but everyone else seems to think this is the power supply (
4900211780). Please - does anyone know which one this is?
Comment by bethcar, posted on Jun 23, 2008
This TV SUCKS it has been the worst mistake of my life. It turns itself off anytime it wants, and one time it did this right in the middle of the super bowl. I hope someone finds a solution soon!!!
Comment by Guest, posted on May 03, 2008
This has been happening to me for about a week. If i leave it unplugged for a day, I can plug it back in and it will work for a few minutes. Then the screen goes dark, at the same time the speaker pops, but the blue light remains on.
Like everyone else I am just outside of the warranty.
Comment by JUNO86, posted on Mar 31, 2008
Mine does this too except I cant get it to work at all. I can unplug it for a minute or a day, and when I plug it back in and turn it on all I get is a blue light. its 13 months old, just outside of the warranty, what a piece.
Comment by Guest, posted on Mar 31, 2008
Comment by alphazero, posted on Jan 16, 2008
I was playing Halo 3 on Xbox Live while this same model just goes black, the audio is still on because its coming from the xbox to stereo, however i didn't notice if any audio was coming from the Lcd itself. Like all of you, the blue light was still on, which usually indicates that the lcd is on. I attempt to reboot the lcd, but the power on/off button is unresponsive, in addition so are the other buttons; volume, channel, and input. i luckily have a back up lcd that i was able to substitue for a few days, when i felt that the westinghouse was ready for a test i powered it up and everything seemed to be normal, then minutes later, the same thing happened, the black screen and the buttons aren't responding. When i say "black screen", it seems like the Lcd isn't sourcing out black light, but more in terms of the lcd looked "off". then yesterday i powered it back on to run some tests on all the inputs; first, the DVI port - 2 hrs no prob. Then the component inputs - 4 hrs no prob. I'm wondering if this is just an intermitent problem or not. and what parts should i buy? if i could hold this thing off for a yr. i'll be able to buy a name brand next time.
Comment by Guest, posted on Jan 06, 2008
power light on, screen light blue haze
Comment by J Evans, posted on Dec 11, 2007
I have a HD Westinghouse TV. The TV suddenly just goes black, blue light stays on, PVR remains on but screen is black. This started happening within the three months of receiving the TV
Comment by Guest, posted on Dec 06, 2007
About two minutes after turning on, the sceen goes black. It will stay this way several minutes and then come back on as normal. This cyclw will repeat itself one or two times over the next ten minutes and then operate as normal. I can watch for several hours with no repeat of this. When the screen goes black, I can sometimes bring the picture back by tapping on the monitor with my hand.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westinghouse LVM-37w1 37 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
