Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a GE profile Artica side by side. I am getting a frost build up in the ice dispenser chute which causes the ice to clog
  • GE Master
  • 1,606 Answers
The ice door flap is not closing completely, or, your using a lot of crushed ice .
Posted on Jul 19, 2009
Frost forms on the inside opening of the chute for the water/ice dispenser. Also frost on the exit chute from the ice cube tray. The frost is present a day or so after I clean it off.
The door flap which releases the ice , on the door , is not closing completely .Usually this is caused by a rusted plunger so both the solenoid and plunger will have to be replaced , These parts are located behind the dispenser board so be sure to remove the top freezer door hinge cover and unplug the plug there , to remove all power going to the door , before attempting this repair . I think the part number is WR62X10055 for the kit .
When it doesn't close , it lets warm air into the freezer and causes frost on the dispenser AND on the ice bin outlet . Also , using 10 glasses or more , of crushed ice a day can cause this .
Aug 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
My ice dispenser in my GE Artica is clogged. There is frost and ice on the dispenser and at the top of the chute. What is the problem?
The dispensor flap is not closing . Usually the flap solenoid rusts causing non closure . When not closing , warm air is sucked in by the fan , causing frost . Without model number , cant give you the part number you need . Solenoid and plunger is the part name .
Aug 09, 2009 | GE Profile Arctica Stainless Steel Top...
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
399 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
