Question about Microsoft Xbox 360 Console
Disk wont open or close
Hi yesterday my 360 broke. My DVD tray cant open or close. The ON/OFF botton keeps flashing the green light (Only in the middle og the big botton). The Xbox startes up as normal and the screen is showing the tray is going to open or close depending on the amount of times i hit the open close botton, but nothing happens.
I pulled out the disk inside when it crashed, the manuel way, as when open an PC disk.
Is there anyone who has the same problem and know what to do about it???
  • 3 more comments
  • Anonymous Nov 19, 2007
    tray doesnt open or close then it does not read the disc says u have to put it in an xbox 360
  • george12345 Nov 22, 2007
    my disc holder only opens, but doesnt close
  • trav 1020 Jan 07, 2008
    my disk tray wont close but it keeps on opening
  • Anonymous Jul 31, 2008
    tray wont open, middle light flashes.
  • dalvon78 Jan 05, 2009
I have had the same problem recently... flashing green lights (only green) and DVD won't reject. Last night, the xbox 360 had the final straw... it wouldn't read anymore games. I can manually eject, but I think there is something worse going on. I think Going to call Microsoft today and see if I can send it back to get it fixed. I have never had a problem with a console before, but am not surprised with microsoft....
Posted on Nov 29, 2007
Well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Posted on Nov 23, 2007
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
XBOX 360 disk tray problems
you arnt gonna find a cd drive that will go easilly into it as they have codes in the boards on them that lock it to the xbox its in and it is quite completed to get the code out of it, can you tell how many lights are flashing on the front?
Jan 20, 2010 | Microsoft Xbox 360 Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont load any games. No red lights but i cant get passed the menu after sighning in. just keeps telling me to open an close tray.
check around the disk tray for dust and use a vaccum cleaner to clean it, then use a wet cd lens cleaner with cleaning fluid a few time.
This should cure the problem but it might be that your drive is dead
Oct 26, 2009 | Microsoft Xbox 360 Console
Blinking green light/won't detect disk drive
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
May 22, 2009 | Microsoft Xbox 360 Pro System Console
Power cuts off
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
Sep 03, 2008 | Microsoft Xbox 360 Console
Disk Tray
Hi! This is a very rare problem. I personally don't know how to fix it but if you have purchased your XBOX 360 in the last 3 years you will have free warranty on it. You may call Microsoft and they will help you troubleshoot and solve/fix your problem. They will explain how the process works once you call. Here is their number:
I hope you get your problem reslolved! :)
Jul 21, 2008 | Microsoft Xbox 360 Console
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Microsoft Xbox 360 Console Logo
347 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
