Question about GE Profile JTP18 Electric Single Oven
My oven shuts off after turning it on makes a clicking noise then shuts off if u mess with it turning it on about 10times it willstay on ge modl jpt 10gp2bg
    Guru:
  • 310 Answers
Do you mean that:
if you program it for bake (or broil) mode it acts like it is working but then shuts off after about 30 seconds?
also, is it actually a jtp10gp?
this is characteristic of a control board failure, I believe it is no-longer-available, good news is that we can fix it for you at www.fixyourboard.com
Posted on Jul 21, 2009
  • 491 Answers
COULD NEED A NEW TERMOSTAT
Posted on Jul 19, 2009
Microwave oven noise
Take it back to the dealer and enquire if this is normal. If it isnt, then exchange it for another and check in the store itself, before you take it home. If it is normal, then you have nothing to worry about :)
Sep 26, 2008 | Ovens
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
Jan 05, 2008 | GE JKS05 Electric Single Oven
GE glasstop stove problem
Try removeing power too unit for a couple minutes. You can due this by turning off breaker. Sometimes this will reset board. If not, you may need an ERC board.
Nov 04, 2007 | GE Profile JTP18 Electric Single Oven
Oven won't stay hot
http://www.lieffcabraser.com/profileovencomplaints.htm
the digital control for the JPT-18 and customer are trying to have GE replace them. It is called the F7 error
Click the link above to see more about the problem. GE wants the customer to pay for the error. Hope this helps. JT
Oct 23, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
257 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
