Question about Lite On (SHW-1635S) DVD RW Dual Layer Burner
I CANNOT GET MY CD TO READ AND BURN A CD.....DVD
I CANNOT GET MY CD PLAYER TO READ AND BURN A CD.....DVD WORKS FINE
  • rrdsqueen Jul 19, 2009
    Thanks so much
    President:
  • 1,179 Answers
Try using a good quality dvd cleaner. The cd lens could be dirty causing cd funstions not to work. There is a different lens for the dvd so it's highly possible that one function will work but not the other if dirty. If this does not work you may have a lens that has become disoriented. If this is the case then with todays priced, decent dvd/cd burner for under $40 it would be cheaper to replace the drive than attempt to repair. Good luck & I hope this helps.
Posted on Jul 19, 2009
3 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: My drive is not reading dvd's
clean the lens of your dvd drive
Posted on Nov 04, 2008
Witchunter
  • 98 Answers
SOURCE: Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 17, 2009
I have a Sony DVD DRU-820A burner. When I insert a dvd--either a blank one to burn or a DVD disc to view--the name of the drive switches from DVD-RAM Drive (D:) to CD Drive (D:). The burner no longer burns...
The device is _partially_ broken -- the part that reads/writes DVD media is "dead".
Spend $40 to purchase a new CD/DVD reader/writer, to replace the "dead" unit.
Dec 20, 2010 | Sony DRU-820A DVD RW Dual Layer Burner
It can't read dvd disc, but if i'm using an mp3/cd its fine
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
Nov 05, 2009 | Jensen's VM9312 Car DVD Player
Avn5500 says "disc check" when i try to play dvds
that is because they are burned DVD- try an original and it will work. Burned dvd's will heat up faster and cause the laser to read through the dvd,
Jun 10, 2009 | Eclipse AVN5500 Car DVD Player
Dvd-audio cd burning issue
If you are burning a "Data Disc" (the burning software should tell you or have you select it) then music will NOT work on a CD-player. It will only work in another PC.
Data disc is for files, pictures, videos, music that you want other COMPUTERS to be able to read and play.
If you want a music CD to work in a car or something like that it NEEDS to be burned as a music disc, not data.
Hope that helps.
Mar 17, 2009 | Gateway GT5056 PC Desktop
How can i burn an audio disc that will play on a cd player and not just my pc?
Modern CD players usually can read all audio disk burned on any computer system.
If you have an older model however you may experience some problem with certain settings, follow instructions below:
1 Ensure that you burn on CD support, and not a DVD, many computer drive can manage the same way CD and DVD, and burn music on DVD, but the player won't read them.
2 Ensure that you are burning an Audio CD on the cd burning, if you will just burn your MP3 files onto a disk, an ordinary CD player won't read them, unless it has MP3 capabilities.
3 If you have an old system try burning at the minimum possible speed , systems built in 80s and early 90s where limited to low speed, some 80s CD drive could read only 2x or 4x.
4 If your system is old also chose close disk after burning option on burning software, this wont affect new cd players.
You also need a software to burn CD, if you do not have burning software , see choice on websites below:
The Best, Free Alternatives to Nero CD/DVD Burner
15 Free CD/DVD burning alternatives to Nero
6 Free Alternatives To Nero | Into Windows
Mar 05, 2009 | Audio Players & Recorders
Hi.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Burned CD's won't play in auto CD player
I had the problem of burned CD's not playing in my car. I used a CD-R and burned it at "slow" burn rate. Now I don't have a problem with playing the cd's in my car player. Try it, it worked for me.
Nov 13, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Dvd player has trouble reading the discs this dvd writer burns
Go to yahoo and do a search for a firmware update putting in the model number of your recorder or visit manufacturer's website see if they have any firmware update available.
Aug 01, 2006 | Sony DW-G120A DVD RW Dual Layer Burner
Lite On (SHW-1635S) DVD RW Dual Layer Burner Logo
355 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
