Question about Kenmore Freezers
Kenmore elite freezer upright, won't stop beeping with 'door ajar'......and not ajar
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
  • 4793 Answers
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Posted on Feb 11, 2010
Door ajar alarm keeps beeping, ice buildup around inside door
I had this same issue and all repair service could do is stop beeping. Finally I sold my refrigerator for cheap and got a new one.
If you don't have the proper equipment to adjust door and seals. better call a repair service and hope they in your case, should help.
Aug 19, 2015 | Frigidaire 20.6 cu. ft. / 583 liter...
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
My kenmore upright freezer won't stop beeping and everything is still frozen ???
hey.. look for a 9 volt battery. its for the memory and power failures .. so it needs to be replaced ..
Oct 19, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Feb 05, 2010 | Freezers
Have a frost free freezer kids left door ajar all
You should unplugged and let all the ice melt and help it with a hair dryer.
Oct 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer beeps all time
check the door for tight closure check switch door if working properly (light closes when pushed) windman
Jan 29, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
307 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
