Question about LG 50PX4DR 50 in. Plasma TV
Red patchs danhulio here again.I should mention that the plasma TV is hooked up to coaxel cable feed.
  • 31 Answers
Plase describe the red patches a little more do they look like red snow, are they only in the right side of the the picture, when you bring up the menu can you see the red over the menu?
Posted on Mar 10, 2008
Antenna hook up
The antenna hooks up at the antenna in coaxel hook up in the back. Same place your cable would hook up to. If you use this for your cable box instead of hdmi then you'll need a cable splitter to attach both.
Feb 05, 2014 | Samsung LN46C650 TV
Samsung 42" Plasma HDTV cable hookup problem
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Jul 30, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Where is the cable hook up on the tv?
This plasma is only a monitor meaning they do not have a tuner, so it doesn't have a cable hook up. If you want to receive over the air channels, if you live in the USA, you will need a digital converter decoder or if you have cable/satellite suscription you will need a cable/satellite decoder box to receive the channels.
The way to connect any of the mentioned devices to your plasma is to use the yellow, red and white cables to the input of the TV and select input 1 or video 1.
If you live where you can still receive over the air analog channels, a VHS should work.
Let me know if you require further assistance.
Aug 13, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
How to hook up cable without using a cable box
this is a monitor plasma tv and it will need some type of tuner to bring the cable channels down to the audio/video jacks or the composite video jacks(blue/red/green) you can use a cable ready vcr to input the video in tv jacks and hook up the cable in to your vcr rf input.
Sep 01, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
How do you hook a dvd player up to a hitachi vcr?
Not knowing the model VCR or TV your asking about here is the most common connections. You will need a video/audio RCA patch cable. This type cable is always included when purchasing a new audio or video appliance. If you don't have this cable they are available at your local Radio Shack, Best Buy and other electronic stores.
On you DVD player locate the three OUTPUT connectors at the back of the unit and plug one end of the color coded (yellow, white, red) patch cable into the corresponding jacks.
Plug the other end of the patch cable into the VCR INPUT jacks, once again matching the yellow, white, red, at the back of your VCR.
That's It!
To see your DVD player on the VCR be sure to select INPUT or LINE on your VCR remote. Some VCR's have an additional set of input jacks at the front of the VCR, usually labeled Front or Line 2. Use whichever one is most convenient.
Aug 29, 2009 | Televison & Video
Havin problem utilizing multiple inputs into Sanyo TV (avg-3259g)
if your tv has no AV IN AND OUT connections, purchase a converter from eletronic shops just around your area.
this will make you convert AV into RF signal and feed that to your tv. you have to go on a channel and search for right frequency the will search for you.
Dec 31, 2008 | Sanyo DS13204 TV
How to hook up a tv to a reciever??
If unit does not have in/output jacks, you can't hook up amps to it directly. However, you can use the cable input from VCR or VTR , then patch in A/V equipment to them. Make sure to switch TV to cable in
Apr 21, 2008 | Audio Players & Recorders
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Fujitsu plasma tv connection problem
the fujitsu pds 4222ws uses bnc connectors. they have all kinds of adaptors to use for any type of wire
Nov 19, 2007 | Fujitsu Plasmavision PDS-4221 42 in....
LG 50PX4DR 50 in. Plasma TV Logo
103 people viewed this question
Computer Repairing
Computer Repairing
