Question about Dryers
Dryer stop running in the middile of a cycle. Checked circut braker all was still on
  • Dryers Master
  • 1,606 Answers
Sounds like a bad thermal fuse . Would need make and model for more info .
Posted on Jul 19, 2009
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
I have no power to my kenmore elite dryer, model 110.87089601. I had a sudden power outgage and checked the circut brakers. Is there a reset button anywhere?
Unfortunately there is not a reset button or circuit breaker or even a fusible link in that model of dryer.
But before you panic, I would recommend that you trip and reset the dryer circuit breaker (unplug the dryer first) in your house circuit breaker panel to make sure it is really set. Then measure the volatage at the outlet for the dryer with a multimeter (remember it is 220V) to make sure you have both 110V legs at the outlet. If everything is good up to the outlet, you will need to open up your dryer cabinet to find out where you lose the voltage. When you get to a point that you have volatage on one side of a component but not on the other - that part is normally bad.
Jun 24, 2011 | Dryers
My GE Dryer just stopped working. The washer is working, I've checked the circut breaker and the GFI breaker and they're all working. Is there a reset button?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2010 | GE DWSR483EBWW Electric Dryer
My dryer stop running and a bad burnt order coming from the inside. Now there is no power to the dyer and it will not turn on. How do I fix the dryer. I have already checked the circut breakers and they...
heatman101
Sep 05, 2010 | Dryers
My dryer quit while drying a load of clothes, it acts as if it has no power. I have checked the brakers and replaced a fuse on the dryer but it still will no run. Any advise?
heatman101
Sep 03, 2010 | Roper Dryers
We own a Maytag Neptune Dryer Model No. MDG5500AWW and have already replaced the mother board. The dryer began beeping periodically and then it just won't start - controls are frozen but they do light up....
If you hear random beeping and a double beep sound when you are pressing a key it means that your problem is the keypad itself, not the board. The keypad on this model is the entire console (not a cheap part @ $200 but this was a very well built dryer so probably worth the repair). You most likely have one of the keys that is shorted out on the console that is causing all of your troubles.
Get yourself a new key-panel part number 33002536 and replace it and you should have your problems solved.
Good luck and please let me know if you have any other questions on this!!
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
The dryer starts up automatically without having to press the start button. will not turn off at the end of cycle, buzzer does not stop, only at the end of one of the 4 cycles.
you have a door switch that is bad, the circut is close so the dryer thinks that the door is still closed. replace your door switch. let me know the model and i will help you through that.
Oct 13, 2009 | Kenmore Dryers
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
Aug 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Dryers Logo
Top Dryers Experts
