Wheres the headlite relay located
SOURCE: 1982 loncoln mark VI
The firing order for that vehicle is: 1-5-4-2-6-3-7-8
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
SOURCE: 1983 Lincoln Continental/Mark VI STARTER SOLENOID WIRING DIAGRAM NEEDED.
the battery cable should be on one post and the fusible links should be on the same post. the other post should be the starter cable only
SOURCE: where is the location of Lincoln Mark 8 VIII
Air Suspension Compressor Motor/Vent Solenoid : Lower RH front corner of engine compartment C134
Air Suspension Switch : Rear side of trunk C458
Air Suspension/EVO Steering Module : Behind RH cowl panel, above connector bracket C204, C205
Air Suspension/EVO Test Connector : RH side of engine compartment, top of wheel well C117 Soft Ride Relay : Under center front of package tray C403Hard Ride Relay : Under center rear of package tray C404 sorry could not find compressor rely listed, good luck
SOURCE: 2002 Lincoln Town Car AC Blower Motor Relay Location
Relays are normally located under the hood in a protective plastic box. Good Luck Ned
SOURCE: Windshield washer pump 1995 Lincoln Mark VIII
should just push in to the bottom of the washer tank, if this one is located inside the front fender, you'll need to remove the plastic inner fender-well to access
