Question about 2wire (1000-400108-001) Router
Reimaged computer can't find IP
My newly reimaged laptop connects just fine vie the cable to my 2wire box, but when I try to connect wirelessly, it can't find an IP. When this happened to me before, I ended up have to open up all my access via DMZ because of how my firewall restrictions are set. (This is a work laptop.) Can you tell me how to set that up again? Or is there a better way?
  • Anonymous Nov 26, 2007
    my laptop can not find my modem
    Scholar:
  • 116 Answers
Much better way! Do you have security setup on your network? Meaning is your Modem/router setup with a WEP or WPA? If so there are a few things that need to be setup when bringing a newly imaged PC onto your network? I have an answer, but can only answer your quesitons or help you with this useful information that I am seeking
Posted on Nov 26, 2007
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
2wire (1000-400108-001) Router Logo
51 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
