Kenmore 24 in. 15079 Built-in Dishwasher
Problem for Kenmore 24 in. 15079 Built-in Dishwasher
Dishes are not clean
By terribeach on Jul 19, 2009
I have a Kenmore Ultraclean QuietGuard Standard dishwasher
some of the dishes don't come clean when i run the dishwasher.....especially glasses and bowls on the top rack
Solution #1
posted on Jul 19, 2009
Somewhat Helpful)
localwonder
Rank: Guru  Kenmore Expert
Rating: 92%, 3010 votes
HI, there are three different reasons why this will occur in this type of unit. inspect these areas carefully.
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2.Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher. Make sure the temp is proper.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15079 Built-in
Questions and Unsolved Problems for Kenmore 24 in. 15079 Built-in
Do you recommend Kenmore 24 in. 15079 Built-in Dishwasher?
Answer
Answer
top rack dishes - glasses are not cleaning properly, water is not draining, cleaned out the bottom... (More)
Answer
Mod # 15835791 Kenmore dishwasher won't drain just makes a bumping noise
Answer
The detergent door is not opening during the wash cycle
Answer
top rack not cleaning --3 yrs old. I've taken the 3 screws out on the bottom--How do I get to the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
