Should I replace catalytic converter and spark plugs to see if that works? Need some answers.
SOURCE: catalytic converter still glowing red
When running does the engine shake back and forth (indicating a skip in the engine) also does it rev up freely. If you were to rev it up to 3500RPMS would it be smooth without the engine shaking back and forth? Also the o2 sensor on the front of the exhaust manifold is pretty easy to get at, if you were able to pull that( 7/8") wrench I beleive) you could tell if it were running rich (sooty black color). In the end you could take it to a muffler shop and for very little money have them inspect your cat, without any cutting or welding. a $20-$30 cost at most. I know the fixya wants us to be self suficiant but even i don't mess with small exhaust work because of the benieft of not dealing with it, especially for such a small price. But if its something you wanted to do, I could explain so. A shop can visually inspect the cat, and see if it is clogged with oil, or excessive fuel. At any rate in the end if they do find that you do need a cat, don't buy a GM one, there are plenty of other sources for an aftermarket cat. IF you decided to go that route i know of a few sources that one could be had for pretty cheap ($50-70) for new. Let me know if any of this helps
SOURCE: need to replace oxygen sensor in chev trailblazer 2002 LS-failed
Yes.....but it would help to get the socket for it. It looks like a normal socket but has a **** down the side to aid in the wires going to it.
SOURCE: 2002 Chevy Trailblazer w/101,000 mi has the P0440
i have 2003 trailblazer ltz 153 000 mileage i have code po440 .i changed gas cap and turned off the chech engine light... i made 300 miles and it was good and today morning i drove a mile and light turned on ..... what do i have to fix ...thanks
SOURCE: 2.2 ecotec engine. Code says random misfire. What
did you fix it? if you did what did you do? i have the same prblm thanks!
SOURCE: failed emissions codes PO404 and P1870
p1870 is a transmission slip code. and usually the passage gets clogged on egr need to clean
