I HAVE AN EMBASSY ts60 SHREDDER-- APPROXIMATELY I MONTH OLD ---- PAPER FEED HAS A SMALL JAM --- HOW DO YOU GET ALL THE LITTLE PIECES OF JAMMED PAPER OUT?
You have to remove the top cover. Look under the top and remove screws. Gently lift top and do not stress the connecting harness. carefully remove paper shreds. Unplug of course!!
we have an intimus 430 se that is having keypad problems.(I think!) It will run in reverse but not...
(More)
we have an intimus 430 se that is having keypad problems.(I think!) It will run in reverse but not forward. Do you know where we can get service in central Illinois?
Paper will only feed through shredder teeth if I press in the plunger / switch the paper normally...
(More)
Paper will only feed through shredder teeth if I press in the plunger / switch the paper normally hits. Paper starts to feed / shred then stops until I press little white plunger switch. What is wrong?
it has been working fine, but today, I emptied the basket and replaced the shredder unit, and it...
(More)
it has been working fine, but today, I emptied the basket and replaced the shredder unit, and it isn't working at all
