Question about Panasonic Viera TH-42PZ80U Plasma TV
Where is the input on the Panasonic Viera remote?
    Top Expert:
  • Panasonic Master
  • 76,060 Answers
It is inside the remote. You have to open the remote to get access to it.
Posted on Oct 05, 2016
SOURCE:
I am having picture problems with my n 64 connected to a Panasonic viera. The picture is black and white and very grainy if anyone can help I would be very grateful thanks
If there is no yellow socket (terminal) on the TV, as in most recent year's VIERAs:
Connect the Yellow male plug from your gaming device into the TV's GREEN female socket (terminal).
Press INPUT on the Panasonic TV remote and select the Video input. In some VIERA models, you need to press INPUT, go down and select the Comp. option and then press >right to select Video.
To get audio (sound), make sure to connect the Red and White plugs from the gaming device into the TV's Red and White sockets (terminals) that are labeled AUDIO.
Mar 26, 2016 | Panasonic Televison & Video
I have a panasonic TC-P50ST30 and viera link will not work with my charter HD DVR cable box. I have a HDMI cable connecting them.What can I do?
Unfortunately, your charter HD DVR cable box is not a Viera link device that is compatible with the TC-P50ST30. Viera Link only works to control Panasonic HDAVI devices that are Viera Link ready (and that use the same Viera link coding) when using the HDMI cable. Thus some Viera link devices of different generations will not work with the same Viera link remote.
The manual for the TC-P50ST30 is available here: http://service.us.panasonic.com/OPERMANPDF/TCP42ST30.PDF . See page 32 for details on the Viera link controls.
I wish that I had better news for you. However, you will need to use separate remotes for your cable box and the TV.
Oct 21, 2011 | Televison & Video
I have a Panasonic Viera tx l37g20b and i am attempting to connect it through a VGA cable. I have connected the laptop to the TV, but there is no option in the TV's menu to select the laptop as the input...
You should have a SOURCE select button on the remote control to select the input source. This should allow you to select the VGA input as the input source. You will also need to make sure your laptop is configured to output a signal via the external VGA port.
Mar 20, 2011 | Panasonic Televison & Video
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
How to get dvb chanels on my tv ?
If you're talking about the DVD then it will depend on what input you have it plugged in to. Follow the cable from your DVD player to your tv and read the name of the plug it is labled with. Hit TV/Video on your remote several times until it gets to that lable on the screen. example, If you have you DVD plugged in to Video 1, hit tv/video button on your remote or on your tv until the cursor highlights video 1. Movie should play.
May 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
How to connect nintendo 64 to panasonic viera tv
it depends what connector cable you have if you have an AV cable hook it into the red white and yellow colored inputs if you have an RS cable for the 64 screw this into the back of the tv where the antenna input is.
Oct 27, 2009 | Panasonic CT-27E13 27" TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
