Question about Microwave Ovens
We have a may tag convection oven tat is displaying error code F5E2
  • Microwave Ovens Master
  • 27,889 Answers
This is a door lock error code. The same error code is also used on top loader laundry washers.
Whirlpool Fault Codes
Posted on Oct 04, 2016
SOURCE:
I have not been able to use the convection portion of my convection microwave oven which is a GE Profile. It tells me that the damper is stuck. How do I remedy this situation?
The damper is a door inside that opens or closes depending on cooking mode (open for microwaving, closed for convection cooking). If the controller senses that the door is not in the right position, it will shut down the cook cycle or display an error code.
This is a problem in one of the damper-related components, either the damper switch or damper motor, or the damper door may be binding.
I can provide more specific help if you will let me know your full model number as shown on the tag inside the cooking cavity or around the door area.
- Ed Miller
http://www.microwavecontrol.com
Oct 25, 2018 | GE Microwave Ovens
The convection part of my GE Microwave/Convection Oven doesn't work. The Microwave part still works fine.
To help you with free DIY or other info, we would need your full model number as shown on the tag in the cooking cavity or elsewhere on the oven.
The FCC ID number from the same tag might be helpful for diagnosis, too.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 10, 2017 | GE Microwave Ovens
ERROR CODE F6-EO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 02, 2016 | KitchenAid Kehu309Sss 30" Microwave...
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
Control display is flashing FS or F3 and then turns itself off
The error code F-S or F-5 is the closest error message I have found in information for your convection microwave oven. The F5 error code indicates that the damper switch has a sensing error. Be sure that the blower outlet is not blocked or restricted. I would recommend calling for service on something like this.
The F3 error code is an indication of a stuck key panel. We do not recommend that the customer remove the cover of their microwave oven. Even with the microwave oven unplugged, there are some components that hold a charge of 25.000 volts.
Note: General resolution for problem is based on information submitted with question. If problem persist, contact a service technician to Sears Repair Department 1-800-469-4663.
Hope this helps (remember to rate and comment this answer).
Jun 29, 2011 | Microwave Ovens
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
I have a Panasonic Dimension 4 Microwave/Convection "The Genius". The microwave stopped working? Can you advise?
So we can help you, please post a NEW FixYa inquiry which includes your full model number from the tag on the unit, and the answer to these questions:
Is it dead? (meaning no display, no beeps when you press a pad on the keypad and the inside light does not come on when you open the door)
Is it running but not heating?
Any usual noises?
Does it shut off after a few seconds when you try to cook with it?
Of so, exactly how many seconds?
Are there any error codes on the display?
Also, if you;re not in the US, which country are you in?
Oct 11, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
