Question about HP Pavilion dv6000z Notebook
When switch on power keyboard lights up but
When switch on power keyboard lights up but screen does not come on
    Novelist:
  • 117 Answers
Try plugging an external monitor into the unit and see if you get a message that it puts the monitor to sleep. also take a flashlight and point it at the screen to see if you see any faint letters in the back. if you do, then your backlight is out and you will need a replacement lcd. if not, then this next part definitely applies to you, if your unit has an AMD sticker on it under the keys then you are eligible for a motherboard replacement. there is a known issue with these units and the boards going out. but you have to act fast they are shutting down these limited enhancement warranties in the next few months.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
go to this link and see if your model is listed here...i am sure it is...if so, contact hp and they will send you a box out to pack your unit it, you can remove your hard drive to save data if necessary and they will send you your unit back in short time with a new motherboard in it.
good luck!
Ruben
Posted on Jul 19, 2009
Turns on, lights up power switch and front of keyboard but screen never turns on
Sounds like the cable between the screen panel and the motherboard has become faulty and will need repairing.
To confirm if there is a problem with the screen, if the laptop has an HDMI/VGA/Displayport, plug it in to a TV or monitor and booting it up. If it shows up normally, then I'd recommend contacting the manufacture.
Oct 23, 2015 | ASUS VivoBook Q301LA-BHI5T02 13.3...
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
Cant get the laptop screen to come up the snooze button light is on
Try holding the power button down for 5 seconds this will fully turn off the laptop - then try switching it back on. Also try removing the battery then switching it back on, hopefully this will clear the fault.
You could also check the keyboard. If you have a faulty keyboard, it maybe that the key that puts the laptop to sleep is faulty. You may need to disconnect the laptop keybaord and use a USB one - if the fault goes away then the fault is with the laptop keyboard.
Hope this helps.
Leon
Feb 09, 2013 | ASUS Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
Gateway 5228 wont boot no lights on keyboard
does it load the bios screen? Does it get to the windows load screens if it does go to the bios screen? Does the computer power on at all?
Sometimes what happens is the bios chip can be faulty or die and this will have to be replaced to fix the issue. If the computer is not powering on then it is more than likely a power supply issue.
(just in case, you might want to make sure that all of the adapters that come from the power supply are connected to the motherboard as well)
Sep 30, 2009 | Gateway Computers & Internet
Acer Aspire 3100 Laptop Monitor will not turn on
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Dec 17, 2008 | Computers & Internet
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Pavilion dv6000z Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
