Toshiba 5560 I have an older copier and the main door got jammed. Now I am getting an interlock error that service must be called. Eevn though the door is now seemingly ok. How can i reset this error code?
  • Arnie Scacchitti
    Arnie Scacchitti Nov 19, 2007
    removed that part from the door and inserted it in the slot and taped it in place. still get the error message. But we may be on the right track. Actually the machine is at my daughters place of business and I am just relaying info.
    Scholar:
  • 95 Answers
Ahh... sounds like the interlock is not getting actuated. Look on the door that is in question, there should be a little "arm" that is bent over, or damaged. That is what actually goes into the door switch and tells it the door is closed. It may be bent over or completely broken off. If you can't find it, look in the inside of the machine for a little slot that looks like something should go into it and then go to the corresponding section on the door. The switch can be "cheated", but that is too dangerous for a novice to fool around with. There is a reason they put that on there as a safety switch, and it prevents the machine from operationg when the door is open and everything is running. There may be several hundred volts running through some of the parts in the charge section, so don't fool around with this if you don't know what you are doing. And as alwyas, be sure to UNPLUG YOUR MACHINE before trying any type of service on any electrical device!!!
Posted on Nov 19, 2007
  • Ken Shepherd
    Ken Shepherd Nov 19, 2007
    Well those door switches can be a little tought to actuate, sometimes you have to really jam it in there. You should try something non conductive, like a piece of plastic, though because sometimes the AC power boards are mounted up front behind that switch, and if you hit that, you'll know real quick!
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
Toshiba E-studio 230 Copier shows this message call for service 631012
Well, first of all Francis, that isn't your error code, that's your meter (the odometer of the copier so to speak). Error codes will show C--- or E---
examples are C447 (fuser error) or E010 (fuser related jam)
Jan 10, 2013 | Toshiba E-studio 230 Copier W/net Print,...
Zanussi washing machine zwf14581w . err e40
Hi.
Error 40 means : "Door Error"
When you get error 40 it is usually because of a defective door interlock.
Try disconnecting power for five minutes. If the error comes back the parts to be tested are door interlock, wiring or main PCB. The defective part must be replaced. Parts and quote on repair can be obtained contacting Zanussi customer service at the number listed on the owners manual.
Regards.
Ginko
Aug 20, 2011 | Zanussi W1042W Front Load Washer
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
Door won't open on wf000
Never reach inside the washing machine with it connected to the mains. The door interlock is always live!
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoint’s - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
A faulty door interlock
The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunged can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank You for contacting Fixya.com
Aug 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Toshiba 2060 wrench call for service error code
thats a problem with the feeder, when you guys moved the copier you may have knocked it slightly out of place, hence the error code to prevent the machine from a miss-feed and jam.
Jul 07, 2009 | Toshiba 2060 Copier
Paper jam and message C570 - Call for service
The C570 is a communication error between the finisher and the main unit. Check to make sure the connector from the finisher to the copier is plugged in properly.
You could try re-seating connectors on the finisher board - it may help.
Make sure the power supply to the copier is not being shared with some other piece of equipment (like on a power strip) that could be causing interference/noise to the power supply for the copier.
If problem persists..could be bad IPC board(finisher) or CPU board (copier).
Hope this helps
Apr 17, 2009 | Toshiba E-STUDIO 850 Copier
Xerox 5760 Color Copier has fault 03-302 at start-up
Xerox 5350, 5352, 5760 Code Description 00-009, 030, 031, 032, 033 A door was opened while paper was being fed 00-047 Paper in duplex 00-1 Auditron 00-2 Diagnostic error 00-3 Faults error 00-4 Ric error 00-5 Job manager system error 00-6 LLM interface 00-7 Standby error 00-8 Communications error 00-9 Xerographic error 01-300 Front interlock 01-310 Right upper interlock 01-315 Left upper interlock 01-320 Left lower interlock 01-325 Fuser interlock 02-910 Key counter missing 02-920 Wrong combination of accessories 03-302, 321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 336 LLM communications problems with edit 03-340 NVM memory 03-341-347 Communications problems between IOT and sorter 03-350-354 Communications problem with LLM and user interface 03-363, 364 Communications problem between LLM & optics 03-370-03-373 Communications problem between LLM & DADF 03-380, 384 03-416-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443-458 RIC problems 03-460 Serial communications processor problem 04-300 Main motor or drive problem 05-100-108 DADF registration sensor 05-110 DADF exit sensor 05-115, 120 DADF jams 05-305 DADF document drive 05-310, 312 DADF document sensor 05-316 DADF registration sensor jam 05-325 DADF exit sensor 05-335, 341, 345 DADF interlock switches 06-300-310 Scan problems 06-315 Scan drive 06-320A, 320B, 320C, 325 Scan problem 06-330 Lens drive 06-340 Exposure control problem 06-342 LLM CPU problem 06-344-350 Exposure cvontrol problem 06-352 IOT CPU problem 07-300, 315, 330, 345 Tray faults 07-360-370 HCF problems 07-375, 380A, 380B Duplex problems 08-100-110 Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1 08-115-162 Feed problem. Lead edge of copy paper is late getting to registration sensor 08-165 Paper jam at registration sensor 08-310-370 Paper at a sensor when power is turned on 08-330 DADF nudger sensor 08-380 Registration side to side problem with home position 08-390 Nip 09-300 Copy cartridge finished (drum unit) 09-310 Add black toner Add color toner 09-320 Add color toner 09-330 Wrong copy cartridge (wrong drum unit) 09-340 Drum cartridge not installed properly 09-350 Waste toner full 100 A fault has occurred 10-100 Exit jam 10-105 Exit jam 10-110 Vertical sensor jam 10-120, 122, 125 Duplex jam 10-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 10-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 10-310 High fuser temperature 10-312 Fuser not up to temperature after energy save 10-314 Fuser problem 10-320 Fuser web finished 10-330, 335, 340 Exit switch, vertical sensor switch actuated when power is turned on 11-100-116 Sorter jam 11-150-176 Sorter auto stapler jam 11-310, 314, 316 Sorter interlock 11-325A,B,C,D,E,F,G Sorter index 11-352, 354, 356 Sorter auto stapler interlocks 11-365A,B,C,D,E Sorter auto stapler bin 11-370,371,372A,373A,373B,374 Sorter auto stapler staple failure, staple home problem or tamper home problem 11-385A,385B,390A,B,C,D,E,396A Sorter auto stapler staple failure, staple home problem or tamper home problem 301 Fuser web must be replaced 302 Copy cartridge (drum unit) must be replaced 501 Tray 1 must be rebuilt 502 Tray 2 must be rebuilt 503 Tray 3 must be rebuilt 504 Tray 4 must be rebuilt 505 HCF must be rebuilt 506 Bypass must be rebuilt 507 Duplex unit must be rebuilt 508 Replace black developer 509 Replace red developer 510 Replace green developer 512 Replace brown developer 513 Copy cartridge (drum unit) will need replacing soon 514 Fuser web will need replacing soon 515 DADF belt should be replaced 516 DADF feed rollers should be replaced 517 Replace exposure lamp 518 Replace suction filter 519 Replace ozone filter 520 Replace optics filter 521 Replace particle filter 522 Replace upper fuser roller 523 Replace fuser pawls 524 Replace pressure roller 525 Replace pressure roller pawls 900-905 Key operator calls
Jan 16, 2009 | Office Equipment & Supplies
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
TOSHIBA DP 1570
you have a jam look for paper make sure all doors are close
Mar 16, 2008 | Office Equipment & Supplies
76 people viewed this question
k24674
jasbo
jasbo
