Question about Rl Flowmaster Garden
We purchased a model 1101hd sprayer but can not understand how to make it work. It sprays nothing. we placed the pink tube in the canister and connected the hose to the spay nostle, and pumped .
  • 47 Answers
Here are full instructions in pdf format, i suggest read and digest. just copy and paste into your browser.
or click on the link
http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/b0d7e529-3d40-4dd6-9708-5f0f2ba04080.pdf
Posted on Jul 20, 2009
Do you know any website relating to paint sprayer reviews?
There are many internet sites on the internet that are providing info associated with paint sprayer reviews. They are especially made for those people who are searching for high quality color sprayer testimonials. Before purchasing it. for more information please visit this website, to understand the product :http://aircompressorjournal.com/top-9-best-paint-sprayer-reviews/
Nov 10, 2016 | Air Tools & Compressors
Volvo c70 windshield sprayer not working
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
Sep 04, 2014 | 2009 Volvo C70
I HAVE A MODEL sx55nxpcd-7443 ailess sprayer that has not been used in 4yesrs I tried to use it today I put a bucket of water for the pick up tube but nothing happens Ihave also missed placed my maunel...
When you say nothing happened.
If the machine doesn't run at all, check the cord and plug.
If the machine doesn't pick up paint, read the following:
There are 2 steel balls inside the sprayer.
The first one is in the pipe at the first joint > this ball keeps prime in the pump head.
The second ball is 5" higher, and it is opened and closed by the prime valve
These balls can rust and then the sprayer needs to be replaced
Always store sprayer filled with kerosene
The prime valve goes bad too
And the intake can be clogged with wasp nest or paint.
Let's say your prime valve is okay, and the pipe is not clogged.
Tap the pipe where the ball is located while the machine is running.
See if you can loosen the ball.
If you can't loosen it, take the pipe apart, but be careful because the ball has to fit perfectly to hold the high pressure of a paint sprayer.
If you can get the machine to prime, then tap the next ball to see if machine will fill the hose.
Oct 22, 2010 | Campbell Hausfeld Airless Spray Guns &...
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
Sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Jan 14, 2009 | Solo Backpack Sprayer
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Garden Logo
815 people viewed this question
Top Rl Flowmaster Garden Experts
andy just round the...
Level 1 Expert
Nick Olsen
Are you a Rl Flowmaster Garden Expert? Answer questions, earn points and help others
