Question about Dishwashers
Dishwasher sticking to one cycle
Does not wash a full cycle
  • 6,784 Answers
HI, this will occur when the timer module is malfunctioning. the timer module will need to be replaced asap, if possible. the mechanism has failed.
This applies to the newer model with control boards as well. the timer module and, control boards are principal initiators of the entire wash cycle and, if in anytime, they fail to advance the cycle properly, they must be replaced.
Posted on Jul 19, 2009
My frigidaire ultra quiet III dishwasher sticks on wash cycle. whats wrong?
Good Morning friend, thanks for your inquiry!
From the information you have provided your Frigidaire dishwasher is sticking on the wash cycle. Do you mean the button is sticking? Or is it stuck on that cycle? If the button is stuck you may have an issue with your keypad and in order to help unstick the button I would push it down to see if that helps alleviate any tension.
If you dishwasher is stuck on the wash cycle I would recommend performing a reset and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to have an issue with your cycles I would suggest having a professional out to properly diagnosis and replace any electrical components. I hope this information has been helpful. -Matt
Apr 06, 2015 | Frigidaire Dishwashers
I have a whirlpool Quiet partner 1 (DU920PWKQ0) that sticks midway thru the wash cycle and continues to wash until the control knob is physically moved, how do I repair this? Thanks
Try to clean the timer assembly using electronic cleaning chemical and ensure the base where the knob rests is also free from sticking.Replacing the timer is the best
Jul 26, 2014 | Dishwashers
Wash cycle knob
It's a quirk of the cycle timer. You can replace the timer ($) or live with it. Besides, a replacement might have the same quirk
Jul 15, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
My wirlpool dishwasher tab compartment don't open through the wash cycle
Clean it out with boiling water, soap residue is making it stick. The compartment is opened by heat during the wash cycle.
Dec 23, 2011 | Dishwashers
Dishwasher turns on & cycles but does not into full wash cycle
Sounds like the timer is sticking. If you had a manual timer I would tell you to advance manually, but you don't. One I can tell you, try turning off the power to it.
May 14, 2011 | Miele 24 in. Novotronic G851SC Plus...
Hotpoint dishwasher. Is the timer out?
maybe the float is sticking. did you check the float switch?
Aug 19, 2009 | Dishwashers
Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Sep 17, 2008 | Siemens 24 in. SL34A006UC Built-in...
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
