Question about Cell Phones
My blackberry bold stop ringing now it doesn sound at all.... no music, no sound notifications, it was ok and all the sudden it stop ringing.....
  • paulareyessm Jul 21, 2009
    nop it did not work
  • 1,272 Answers
Go to the profile that you are using and set the ringtone and sound volume here.It should work.
Also, make sure to upgrade the BB to the latest firmware available.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 21, 2009
  • Anand Gupta
    Anand Gupta Jul 28, 2009
    Has the issue resolved? If not, then please let me know so that we can work for a solution!
    Regards
    Anand
    President:
  • 2,559 Answers
Just press and hold the # key untill you see silent mode disabled on the screen.
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
No sounds when have call, sms, bbm and all coming alert anything but when I play music have.. Please help me!!!
Hi pulera zoluz this is a simple fix for you. One you need to go to the sounds profile. In the profiles you need to change the notificatons. If you hit the ball you can set up the notifications on your phone. It will give you a list of all your profiles. soft loud no alerts. Ok hope this helps.
Dec 29, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry bold 9700 just stopped ringing in the middle of a call. It will vibrate & play the sound on videos but even though the volume & everything is turned up - it still won't make any...
have you tried removing the battery for one full minute?... try it if still doesnt work try a master reset...you will have to back up phone first
Sep 30, 2010 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry Bold 9000 volume from media player is down even though the phone volume is OK
May be are you listing this music in handset option
Follow up;
Play any music , press menu button select “active Speaker phone”
Then try.
Jul 14, 2010 | RIM BlackBerry Bold 9000 Smartphone
My phone wont ring and when i try to play any music it says device media processor is busy.. i have a blackberry 9700
sounds like you have a memory leak ... you may want to try uninstalling some applications to restore more available devices memory to the applications you want to use. good luck
Jun 10, 2010 | RIM BlackBerry Bold 9700 Smartphone
I have a new blackberry bold and even though the volume is set at high my phone still rings very low and also the music and i am frustrated
Use the side key on the right side of your blackberry bold and this should settle it, if that fails to work go to Options>Profiles>Loud.
This should do.
Kind Regards
Feb 27, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry suddenly stopped making noise. The ring, alarm or music will not work. It still vibrates but no noise comes out of it.
You have to pop the battery out to reboot it...happens ALL the time!!! I have to do it almost every other day
Oct 05, 2009 | RIM BlackBerry Pearl 8100
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
Sep 11, 2009 | RIM BlackBerry Pearl 8100
Cell Phones Logo
350 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
