Question about Saeco Vienna De Luxe Espresso Machine
My Saeco Vienna De Luxe machine leaks water to the base. It has leaked before from the outlet at the reservoir. I fixed that. It also leaked at the drain outlet behind the brew group. This is the third leak. Now, it leaks even when the reservoir is not installed, and the drain hole is clear. Apparently, a leak from the boiler or the fittings. Any fix?
    President:
  • 1,618 Answers
It is possible that the o-rings in the hose fittings are worn out and need to be replaced.
Posted on Jul 19, 2009
  • 1,089 Answers
Hi
That sounds like the boiler is leaking. This is usually caused by scale build up between the boiler halves. It builds up on the haves and then the seals don't seal. If you can remove the top, you can check the boiler located on the left side. There are 2 yellow wires on the top. if you can see a white line on the boiler that would be scale and that is bad. Descaling is good but descaling correctly to even better. Heat and the descaling solution will cause the seals to harden and this will cause the boiler to leak faster. Check Ebay for boilers, I have seen them before.
Posted on Oct 17, 2009
    Scholar:
  • 70 Answers
If its leaking from under the drip tray 99% of the time its a boiler leak. Most likely has to be sent in as changing a boiler requires the boiler, gaskets, and a few other fittings possibly being changed.
www.saecooutlet.com has a list of service centers where you can send you machine to.
Posted on Sep 10, 2009
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
My Saeco Vienna Deluxe has water leaking out from somewhere underneath - clear water.
There are so many places to check, but lets check the small chamber under the white plastic valve, which sits behind the brew unit, clean out the chamber of coffee grounds. If that is not the cause then, you will have to open the machine to find the leak.
Feb 17, 2010 | Saeco Vienna De Luxe Espresso Machine
Our Vienna, Superautomatica leaks water from underneath
your problem may be in the watertank. I had that problem, and found out, the metalfeder fastened so it stayed open, after making a cup of espresso.
Nov 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Water reservoir leaks intermittently
Saeco use the same seal under the grey plastic ring on most of their coffee machines so it should be easy to find a replacement from any Saeco, Spidem or Gaggia service centre.
In most cases the seal isn't worn, it just isn't sitting right, so remove the grey cap (two flat screw drivers to lever from both sides at the same time helps) and reposition it. This is usually all that is needed if the problem is only intermittent.
Also check that there isn't anything sitting in recesses where the legs of the water container sit. It only takes a tiny bit of dirt to stop the container sitting in far enough to seal.
However, make sure the leak isn't coming from the container itself. Hold the container up with water in it and see if it drips. Check the the spring is clean.
Nov 26, 2007 | Saeco Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
2,368 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
