Question about Microwave Ovens
Sylvania microwave 11092B/SR-11092BNG quit working
While cooking, opened door to remove item. Closed door and tried to reset cook time but none of the buttons worked. Did hard reset several times with no success. When plugging back in the unit goes through a start up sequence asking for the clock to be reset but none of the buttons work. Then it locks up with clock in the bottom left corner. I do not see moisture anywhere and the unit was used pretty regularly until this happened. Craig
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
najah
  • 180 Answers
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker XL1400, Model number JVM1430WA 001
OOPS!
I meant to post that as a solution, not a clarification request, so it came out as one big blob paragraph (Thanks, FiyXa!)
Here it is again, but in readable form:
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It is part number WB27X10171 and while GE sells it for a whopping $115.50, you can get it for $90.58 here.
You can also find helpful exploded view diagrams via that link.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs, in this case
$90.58 plus $8.95 shipping for a total of $139.48.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 25, 2009
garing
  • 998 Answers
SOURCE: Just quit working, the keypad doen't work but if
check all door switches if ok next is key pad
Posted on Aug 17, 2009
Sylvania 11092B SR microwave problem?
you can check the fuse with a multimeter or take it to the hardware store and get a new one. they are cheaper than a new microwave. If it still blows the microwave fuse check for magnetron numbers may need to replace it.
Jan 08, 2014 | Microwave Ovens
Kenmore microwave 85609 has a 5E code on it
test this steps and fix it. God bless you
  1. Power Issues
    • If your microwave oven won't come on, ensure that the power cord is plugged into an outlet and that the power is on. Replace any blown fuses, and reset a tripped circuit breaker. If the microwave won't run, see that the door is completely closed and that nothing is stuck in it. Ensure that your door is not broken. Replace if necessary. See that you have not started the timer as opposed to the cooking function. Press "Start/Enter" to start your microwave.
    Clock
    • Your display will flash if your power goes out. You must reset the clock. If you do not hear a tone at the end of cooking, ensure that you have enabled the audible tone. Also check that you are using the right command. If your power goes out while your food is cooking, you must reset both the cooking time and clock.
    • Sponsored Links
    Cooking
    • If you see sparks while you are cooking, remove any metal objects or plates with silver or gold trim. If your food is taking too long to cook, ensure that you have selected the correct power level for the food item. Remove any other appliance from the 20-amp circuit line. Additional appliances on the same amp will draw too much power away from the microwave. Also ensure that you have selected the correct food item in the preprogrammed menu. Each microwave has its own error codes. Always read your manual to determine what the error code means. Examples of error codes include "E-11", "E-12" and "E-13." This means that you have a defective sensor, and you must get your microwave serviced. The "SE" error code indicates an issue with your control panel.
    Additional Problems
    • You may hear gear noises, especially a humming noise; the fan will automatically come on while your food is cooking. If your turntable plate makes noise, first clean it, and then see that it is positioned correctly over the roller ring. If your nearby appliances are experiencing electrical interference, move your microwave farther away to correct this problem.
Jul 22, 2013 | Microwave Ovens
Stopped cooking
This is technical!!! Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right inside of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
Jan 30, 2018 | Advent Mw912bwdk Black Built-in Microwave...
The microwave (Sylvania SR11092B) has power but nothing on the key pad works no matter what you push. Help!!
How do I order a control panel for a Sylvania SR-11092B/SR-11092BNG microwave for my RV?
Jul 23, 2011 | Microwave Ovens
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Microwave Ovens Logo
547 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
