Question about American Standard 1583.470 Universal Drain, White
I HAVE THE AMERICAN STANDARD WALK IN TUB WITH THE QUICK DRAIN AND WHEN I FILL IT UP TO USE THE JETS, THE DRAIN WILL NOT RELEASE TO LET THE WATER OUT. WHAT MIGHT BE THE PROBLEM?
  • 117 Answers
It could be the pressure on the drain isn't allowing the rubber around the drain pop up to come unlodged from the floor of the tub. I have ran into this problem a few times. the best way we found to take care of it was to install a push pull type drain assembly or try and adjust the drain pop up so it pops up higher allowing the rubber around it to break the seal and start to drain. take some pictures and post them i might be able to help more
Posted on Jul 28, 2009
Sandy,
Please give AMSTD Walk in Baths a call. They will be able to answer any questions and walk you through the process of fixing the problem.
AMSTD Walk in Baths
866-423-0800
Posted on Aug 26, 2009
How long does it take to fill an American Standard 3260-210
It holds 80 gallons. How big is your inlet pipe? How much water pressure? How many gallons per minute? Then you will have your answer.
Oct 13, 2014 | American Standard Walk-In Bath 30" x 60"...
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
My upstairs tub leaked and can see large water stains on the first floor ceiling. I think it only leaks if the jets are turned on. how do you fix this?
you will want to fill the tub up and turn the tub on first and get behind the tub and see where the water is coming from. there isn't any other way to find the leak.
Oct 15, 2009 | American Standard Home
American Standard 1583.470 Universal Drain, White Logo
685 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
