Question about Microwave Ovens
Hello I have a Grohe 33755 faucet. I can not gwet hot water out of it and it is brand new kevin
  • kmcgrath1958 Jul 19, 2009
    NO
    i NEED SOMEONE WHO UNDERSTANDS THE MODEL 33755 GROHEN. YOUR SOLUTIONS ARE SIMPLE AND VERY BASIC
    KEVIN
    No
    This is too basic the model 33775 Grohe has cartidges that keep the lime out. I suspect it could be in the cartrige somewhere
    Kevin
    President:
  • 1,129 Answers
The cartrige may be installed wrong flip it around.
Posted on Jul 19, 2009
    President:
  • 1,734 Answers
Just re-do the installation and ensure the following steps:
Remove the mounting nut, metal washer, fiber washer and spacer from the faucet.
Place the faucet with sealing ring on the mounting surface.
If the mounting surface is less than 1 3/8” thick, install the gray plastic spacer. If the mounting surface is greater than 1 3/8”, or if there is insufficient space, omit the spacer.
Install the fiber washer, metal washer and mounting nut.
Tighten the mounting nut and screws.
Then install the handspray hose:
Connect the supply hoses
Use 3/8” compression fittings (not included) to connect the supply hoses to the stops. Use two wrenches, as shown in the diagram, to keep the supply hose from twisting.
Do not allow either hose to twist.
Twisting the supply hose may cause it to loosen from the faucet, which may cause water damage.
Twisting the handspray hose may cause reduced water flow to the handspray.
Slide the nut, cone washer, brass washer and black rubber washer over the end of the connecting hose.
Hold the handspray hose steady while tightening the nut. Finish tightening the nut with a wrench.
Then install the hose weight:
Proper positioning of the hose weight insures that the hose will retract smoothly.
Install the hose weight on the handspray hose. Pull the hose out and guide it back into position. If it does not retract smoothly, or the sprayhead does not stay in place when resting in the spout, reposition the weight.
Last but not least turn on the water and check all connections for leaks.
    President:
  • 2,777 Answers
Hello there Kevin, make sure you check both hot and cold water connections under the faucet. Feel the tube / pipe that the hot water is connected to, is it warm to the touch? It should be if it's working properly, if not then you aren't even getting hot water to your line. Make sure the valves under the faucet are turned on fully, I assume you get hot water everywhere else in the house?
Thanks sir, let me know, we will get this figured out.
Tim
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
Sep 19, 2011 | Microwave Ovens
Don't know what the extra water line is for on my new kitchen faucet
Is it for the auxiliary sprayer that you may not have? You don't give much information about your new faucet except you do say it is on your microwave oven. I could give better help if I had an idea what make/brand/model it was.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Microwave Ovens
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
I'm trying to change the kitchen faucet and the shut off valves under the sink will not turn, I've tried to spray them with WD40 but they still won't turn. I live in a Condo so I cannot shut...
If you can't work the shutoffs on the water lines under the sink, your only choice is to contact your condo maintenance people. They need to have some way to shut the water off to your unit when they make repairs. They can tell you if there are some more valves in another area that you can access, or they may have a maintenance closet somewhere and can turn the water off for you so you can make the repair.
Sometimes you can turn a sticky valve by using a large set of channel-lock pliers or similar type on the knob so you can get leverage. They look like this if you're not familiar with the type:
If it's been a while since the valves have been used, they often don't want to move without help. Once free, they may work fine, but sometimes it's a good idea to replace the shutoff valves as part of the new faucet installation. They're not expensive and you'll know they will work if you need to shut them off in the future. Get "ball-valve stops" which make a positive shutoff. Stops that use a rubber washer can sometimes let water trickle through (or more than trickle!) when shut off. Depending on the kind of valves currently installed and the type of pipes supplying your water, you might want the condo maintenance people to do the replacement. But if 1/2-inch copper pipe is what you have and there's a couple of inches between where the pipe comes through the cabinet back or bottom and the current valves, you can just cut them off with a tubing cutter. Then you can replace them with valves that just slide over the pipe and are fastened by tightening down a compression fitting (tightening a nut, in other words).
You should also plan to use new supply lines from the shutoffs to the faucet. Again, they're cheap and the old ones can sometimes leak when you try reconnecting them. Corrosion and mineral build-up from hard water can lead to poor sealing. The current ones may also be clogged with minerals, and new ones will give your new faucet full flow.
Once you've got that problem of turning off the water supply solved, it's usually not too difficult to change the faucet. Make sure you have a basin wrench on hand; on many faucets it's impossible to reach the supply connections with any other kind. The box from the new faucet may tell you if can get away without one.
Good luck with the project, and thanks for using Fixya!
May 28, 2011 | Microwave Ovens
I have installed the muirfield model kitchen faucet. I attached the water hoses and I am not getting hot water when I turn to hot. I am only getting a trickle. bith my hot and cold water is turned on all...
You are going to have to take the line off again and check it for debris or any plastic guides that have slipped out of place. You may have an internal clogg caused by something getting into the hot side of the faucet. Check any screens on the faucet for pluggage.
May 06, 2011 | Microwave Ovens
I have a cold inlet only. When opening cold water inlet, water gushes out by hot water inlet. How can I block off the hot water inlet?
there is a y adapter which consists of two hose outputs to one hose input...you could use this by attaching the two hoses from the inlets to the Y adapter and then get another hose to go from the y to the water faucet...the adapter is available at most hardware stores
Apr 27, 2011 | Microwave Ovens
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
Mar 10, 2011 | Microwave Ovens
My husband installed a new KWC Domo faucet in our kitchen yesterday. When he was finished, he turned the faucet on and got a trickle of water. We are stumped and the instructions are no help.
Take off the aerator from the spout (it just screws on, and should not be so tight you need a wrench) and then run the water. You'll probably find the aerator screen is clogged with debris and you can wash it off. This often happens when you turn the water supply off to connect the new faucet. After you clean off the aerator and screw it back into place your new faucet should work fine.
Feb 27, 2011 | Microwave Ovens
I have a grohe model 33 790 and it is dripping so i assume the cartridge needs to be replaced. how do i get the cover off to get to it stansevey@aol.com
You shouldn't have posted this in the microwave oven section - the 33790 is a faucet!
Facing the faucet, on the right (where the lever is) the en-cap is bayonet mounted - twist and pull.
To remove the cartridge, there is a key that needs to be pullet out from the cavity , the lever unhooked and the cartridge pulls out. The replacement o-rings and special oval seals are available from Guillen in Florida.
Aug 22, 2010 | Microwave Ovens
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
