Hello, I have a Daewoo Plasma TV, model number DP 42-SM. I'm trying to troubleshoot the problems on the TV in an attempt to repair it myself; every repair shop I've called has said to "just buy another TV." I do not want nor can I afford to do that. The problems are these: when plugged into either the main component 1 or 2 jacks, I get a picture with a green hue. Then after a short while (about 20 minutes), it turns completely green. On the s-video and the other video jacks, I do get a picture with no color problems; however, it "flashes" on and off. Sometimes, I get a frozen image while the screen blinks on with the picture. The audio comes in clearly and uninterrupted. I have ordered a service manual and have narrowed the problem down to either video pcb board, or the jack pcb. I don't have the equipment to test either of them down to component level. Can you please give some input on which part to order, or both?
  • erica_cooley Jul 19, 2009
    Hi plaboy,
    Thanks for the suggestions. Upon more troubleshooting, I realized that I had the audio output from my cable box plugged directly into my surround sound receiver. When I connected speakers directly to the TV, I discovered that the audio cuts out when the video does. Is this indicative of a bad video PCB? Or, could it instead be the digital PCB which produces the control signals?
    As I said before, I'm trying to do this on my own; I'm not a video repairperson, I'm just a person with an Associates degree in electronics and is tired of being told to buy another tv. I don't have the test equipment to run the checks you've indicated. I'm looking for a quick and easy solution, if there is one. Any assistance is greatly appreciated.
    Thanks!
    Thanks, palaboy! That really narrows it down for me and hopefully saves me some money in the process!
  • 5,807 Answers
first we check on the video PCB board
a) the video .... board operates on at least 200v
b) getting a green raster means the other video output transistors are not working.
c) check the supply rails of 12v or 9v , supply might be low or intermittent
Second we check on the power supply
a) check if there are bulge capacitor on the power board
b) check the supply rail of 12v
check the diode
check the capacitor
3rd if you have auxiliary power supply
you need to supply the 12v with it and note down the voltage reading on it
a ) if the voltage drops more when connected
b) or the circuits have getting too much current
4th a good multimeter will help you the most in assessing where the trouble might be
Voltage reading might be the first to do and have a note on it
Visual indication of bulge indicates a faulty circuit
Visual indication of cold solder on PCB foil path indicates fault on the circuit
hope my suggestions helps, thanks for using Fixya!
All of these will be done with a help.
Posted on Jul 19, 2009
  • Rommel Cana
    Rommel Cana Jul 19, 2009
    hi,
    it is just my suggestion,
    the quickest and easy solution might be to replace circuits boards.
    the candidates are:
    1) power supply board
    2 )digital circuit board
    3) both 1 & 2
I have a daewoo plasma tv model dp-42sm with no video after taking back cover off found the x- sustain pcb with a burnt ic chip labeled iu4. after removing defective pcb and powering up tv set power stays...
I have the Daewoo Plasma Digital Dream model dp-42sm and it had power but no picture and my dads tv expert friend looked at it said the ysus board was out. I got the part on ebay for 125 dollars with 12 dollar shipping and put it in myself very simple and the problem is fixed. Is this the same issue your having?
Dec 17, 2009 | Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo 42" Plasma dp-42sm lines in screen
The problem is you have a cold solder joint on a component on the flex harness. My son will show you have to fix it on YOUTUBE. Check it out!
http://www.youtube.com/watch?v=EFpXYnGZCU0
Jan 14, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo Plasma DT-4280NH
Hello nkoomy,
This is a sign of a bad scan driver board
Jul 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DTS42 plasma problems, please help!
The PDP (plasma display panel) is defective and needs to be replaced. The big problem is that Daewoo no longer carries replacement panels for this model. I'm in the same boat you're in. I hate to throw away the tv so I'm waiting to see if I can find a replacement panel on ebay.
May 13, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo screen in a samsung
Theoretically yes functionally no. Not unless the parts are the same, chack the model numbers of the plasma screens. If they match you can change them out, if not don't try it.
Sep 21, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
