Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Icemaker does not work
Icemaker does not produce ice. Water dispenser works fine. I'm assuming the same waterline supplies both the icemaker and the water dispenser. Unlike the other post, I do not see any type of error message on my display. Any advise?
    Champion:
  • 363 Answers
Does your unit have the cube size selection button inside of the ice maker door , if so is it lit up, if so is it on a cube selection. If not that is the reason the ice maker is not working because even though the unit is on the cube selection has not been made. This should solve your problem.
Posted on Jul 19, 2009
Why has my GSS25 ice maker quit working? Water dispenser is fine.
The icemaker could be frozen where the water supply comes into the icemaker this sometimes happens if the water was recently shut off or you had low water pressure. Unplug the fridge and try using a hairdryer to defrost where the waterline comes into the freezer. I would assume you already checked to see the icemaker was turned on and the bail was in the down position. If you did All things i mentioned plug in the fridge and test if it still won't make ice afterwards you will need to replace the icemaker. The replacement should come with instructions.
Aug 01, 2014 | GE GSS25JEMWW Side by Side
ICE MAKER NOT PRODUCING ICE. WATER IS GETTING TO LINE; WATER DISPENSER IS WORKING FINE, MOTOR ON ICE MAKER IS WORKING. THIS PROBLEM STARTED AFTER WATER LINE TO FRIG FROZE DURING COLD SPELL.
Remove the icemaker and check the incoming water line. It may be frozen.
This icemaker manual may be of some help to you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/9e1ec3936ebd443e852572fa00675934/$FILE/4316835.pdf
Jan 17, 2010 | Refrigerators
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
No water in the ice maker
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
Sep 06, 2009 | Maytag MFD2561HE Bottom Freezer French...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
342 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
