Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Profile Arctica with Freezer on top and refrigerator below. Problem is freezer door pops open when refrigerator is closed. This causes high energy bill and frozen food to spoil.
  • 1 more comment
  • jcameron91 Jul 19, 2009
    Thanks for your idea - please give me more detail.
    1) what am I looking for when I check the door seal?
    2) using hair dryer to heat the seal - do you find this can be done on the entire perimeter of the seal or should this be done on one side at a time?
    3) I can buy new seal on internet for $55. How can I diagnose if this is necessary?
  • jcameron91 Jul 21, 2009
    It seems that I have bigger problems than just the freezer door popping open. I incorrectly assumed that because the freezer door was popping open - that this was the cause of the freezer warming up.
    However - after paying more attention - I find that both the freezer AND the refrigerator are warming up.
    I vacuumed the dirt (there was a lot) off the fins on the heat exchanger located at the back of the unit (after removing the sheet metal plate first) but this did not seem to help.
    Several hours later my I next noticed that the digitally displayed temperatures for the top and the bottom seemed to be going in the right direction again (cooling). However, today both units are back up to 53 deg even though I used tape to keep the freezer shut.
    It seems someing more fundamental might be broken or working intermittently.
    Thanks for detailed correspondence. I am happy to try and isolate the problem with your help.
    There is no ice because both top and bottom chambers are both 53 to 59 degrees F (there is a digital display built into frame that separates the two. This display is visible when you open the refrigerator door (the lower half). Since both chambers act up - this means two thermocouples would have had to fail? Or a shared part of this system?
    I can hear a fan running - so air is circulating - but it is not very cool air. Ambient temperature is about 70 to 80 deg F.
  • 441 Answers
The best way to fix this is to run the front leveling legs down more. You want the Ref to lean backward some so the doors close when this happens. What is going on is that when you close one door the air is pushed back into the other compartment and pops the door, this will happen less with time but for now have some one lean the unit back a bit, run the legs down untill it leans back. A good way to test is hold the door open at a 90 degree angle and just let go. if it shuts on its own it is good to go, if not run the front legs down a little more. Good luck
Posted on Jul 21, 2009
  • 145 Answers
In all honesty, this is not necessarily a FIX, but will at least help you identify which parts of your refrigerator may be malfunctioning and causing this problem.
You may have frost build-up on the evaporator coils. If this is the case, the unit's fan is not going to be able to circulate air effectively through the unit. These coils are usually located in the back of the freezer and may be accessed through a removable panel if you have an older machine. In newer machines, the coils are located underneath with another removable panel.
If these panels are covered in ice, you will want to remove as much food as you can from the refrigerator / freeze and leave it open. This will allow the unit to thoroughly defrost. To speed up the process, you might put steaming pots of water on the shelves. Once all the ice has melted away, turn your refrigerator's thermostat back to a normal setting. If your refrigerator regains its ability to cool, this will indicate that the unit's timer, heater, or thermostat has failed.
At least this step will narrow down what it is we're looking for.
  • GE Master
  • 1,606 Answers
Check the door seal . If not closing sealing completely , use a hair dryer to soften up the rubber seal and the seal should draw itself to the cabinet . If sealed , you should hear a slight snap when door is closed .
Posted on Jul 19, 2009
  • Mike Smith
    Mike Smith Jul 19, 2009
    You would see a slight "crack" between where the magnetic portion of the seal seals against the cabinet .
  • Mike Smith
    Only need to heat the portion which is not sealing .
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
