Question about GE GSH25JSSS
Water dispenser doesnt work, ice dispenser works fine
Second time that water dispenser stops working. Replaced filter first time and fixed problem, but I just bought the filter and now it stopped working again. Manual says that water reservoir is frozen. How do I find it or what do I do?
  • GE Master
  • 1,606 Answers
1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)
Posted on Jul 19, 2009
How to fix my Refrigerator water dispenser?
This is a duplicate post. To see the original post Click HERE
Water to the ice maker and to the dispenser are turned on and off by a coil on the dual water control valve. Unfortunately these coils cannot remain on for long extended periods of time. If the coils remain on for extended times they heat up and it's very possible that the coil on the water control valve for the dispenser has burned out. I'll get the part number and a description photo for you if you would like. I'm here and available for questions if you need any answers Thank You, John T. Appliance 911
May 08, 2014 | KitchenAid Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
How to fix my water Dispenser on my Kitchenaid kscs25ftss02 refrigerator?
Water to the ice maker and to the dispenser are turned on and off by a coil on the dual water control valve. Unfortunately these coils cannot remain on for long extended periods of time. If the coils remain on for extended times they heat up and it's very possible that the coil on the water control valve for the dispenser has burned out. I'll get the part number and a description photo for you if you would like. I'm here and available for questions if you need any answers Thank you John Tripp
May 08, 2014 | Maytag MSD2756G Side by Side Refrigerator
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
465 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
