2010 Chevrolet Chevrolet Cobalt LT Logo
A
Anonymous Posted on Oct 02, 2016
What does code p031 mean, engine light is on. Light stays on while driving.
Engine light went on. code is p031. whay does this mean?????
magna buff
Level 3:
  • Chevrolet Master 3,828 Answers
  • Posted on Oct 02, 2016
magna buff
Chevrolet Master
Level 3:
Answers
3828
Questions
0
Helped
1112028
Points
21593
Oxygen sensor heater circuit failure
check wiring to it ,its relay or replace 02 sensor
https://www.obd-codes.com/p0031
2answers
P1740 ford
Four digit codes are brand specific. The only info I have on 1740 for a Ford product involves the transmission but not a specific part.
Its possible the code was a fluke since it went off, but I would want someone to check it out just in case.
Whay does code 31, line solenoid open means?
the solinoid stays open,might be stuck,or cloged,have the transmision flushed and replace the hydrolick filter inside the transmision
1helpful
U0155 code
The U0155 means "Lost Communication With Instrument Panel Cluster(IPC) Control Module".
_________________
autocom cdp pro plus
2answers
What does the check engine light mean?
  • A check engine light means a sensor in the car malfunctioned and sent an error to the cars computer and in turn that light came on. So now you have to get the codes pulled and then write them down and the codes themselves will tell you what caused the light and how to go about fixing the car so the light stays away. You can get the codes read for free at your local major parts store. This can be something minor, a glitch or something more major going on but until you pull the codes you will not know.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
5helpful
3answers
When the vsc trac light comes on my 2003 Toyota 4 Runner, what does that mean?
As long as it does'nt stay on it's doing what it's suposed to be doing which is saving you from going out of control. It'll come on more often if you drive like hell, run with low tracktion tires or worn out ones and if the air pressure is low. If your tires have over 80,000 miles on them even if the tread is still good their bad tires as their skating along and the trackstion system is working hard to keep the car under control. If the tires aren't al the same size it'll do it to. ( fronts worn out backs still with tread.) Mis matched tires too. Ifthe light stays on other light's are bound to be coming on too the ABS light the brake light, and even the engine light as their all involved in traction control.
1helpful
Check engine light code P031 for 2002 Dodge Ram 1500, what does it mean?
Dear Madam or Sir,
the code stands for:
Heated Oxigen Sensor1, Bank 1, Heater Control - circuit low.
So the heating of the O2 Sensor is faulty, you should see a mechanic to fix it.
Yellow engine light went on. What does this mean?
The yellow/orange Engine Check Light is an indicator that your vehicle's computer has detected an abnormality within the engine's electronics or emission system.
Sometimes it can be a one-off abnormality, which eventually rectifies itself within 40 drive cycles.
However, if the Engine light remains lit, then this is an indication of something more concerning (but not necessarily serious).
If it does remain lit when driving, then you should have your local Jaguar service agent scan the computer for "trouble codes", which will quickly identify the component and/or location of the problem.
Hope this helps...
Cheers,
3helpful
2answers
Code drive 5 . My 2004 trailblazer posted a code "drive 5". It showed the "reduced engine poweer" light, and would not respond to the accelerator pedal. I had been driving in slow traffic. I pulled over,...
Thottle body sensor, accelerator pedal sensor, restricted air flow...will all trigger this fault light. Go to your local Autozone, they will run an OBD scan for free, and explain the fault codes to you so the correct repairs can be made.
Good luck...i hope this helps, please rate me a fixya.
Engine light keeps flashing and all tar,snow and gravel lights
USUALLY A FLASHING ENGINE LIGHT MEANS A MISS FIRE CODE DID YOU HAVE THE VEHICLE HOOKED UP TO A SCANER? IM NOT UNDERSTANDING WHAT YOU MEAN ABOUT THE SNOW GRAVEL AND TAR LIGHTS
3helpful
Over drive light on shifter blinks and check engine light is lit.
You need to have it scanned for codes. The flashing overdrive light means it has trouble codes that pertain to the transmission.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
