I can only get sound from my main kenwood speaker. I cannot get sound from my secondary speakers.
    Genius:
  • 1,043 Answers
I believe a chat window opened up from you to me earlier today. Can you briefly tell me what you have already tried with your receiver? There may be a few more steps we can try to take. Thank you.
Posted on Jul 19, 2009
I'm trying to run advent as2 speakers with a kenwood vr5900 receiver but they are clipping
You can not do that, it will result in catatrophic failure in the output stage which will prove very costly if you continue.
Mar 29, 2012 | Recoton Advent Advent AS2 Main / Stereo...
After driving for about thirty minutes my amp will just cut off, it seems a little hot and then it will turn back on in about 10 minutes. I'm not playing my music loud at all and I have all kenwood...
sounds like your speaker is either the wrong resistance for your amp ie your amp may state 4 ohms and your speaker is 2 ohms which means that the speaker is shorting out the amp and its going into protection mode or the speaker could be burning out and shorting out the amp
May 30, 2011 | Car Audio & Video
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
What kind speaker use my kenwood powered subwoofer 103SW
It uses a 10 inch, 4 ohm speaker, probably rated at 100 watts. If you are getting no sound, check your connections. Or, the subwoofer amp may be blown.
Aug 29, 2010 | Kenwood 103SW Speaker
Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Kenwood 138 and Performance Teknique 752 speaker problem
Hello passionatete,
It sure sounds like the speakers are bad. When I looked these up, the specifications said they are 5 1/4 inch. You should listen to a few different speakers in the size that you require, to see what ones you like best. I'd first make sure of the exact size. Many 5 1/4" speakers have tabs that allow them to be mounted in 6 1/2" openings. The best way to determine which speakers fit is to use the "outfit my car" feature at www.crutchfield.com. They have speakers starting at around $35 per pair. Another good online site for research and for purchase is www.sonicelectronix.com. Sonicelectronix sells speakers starting as low as about $20 per pair.
Kenwood, JVC, Sony, Blaupunkt, and Orion are all excellent speakers for under $30. There's others like Boss, Scosche, Power Acoustik, and Visonik that cost even less. Again, I'd listen first, and then buy.
Hope this helps.
May 17, 2009 | Performance Teknique ICBM-752 Coaxial Car...
Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Mar 16, 2009 | Kenwood VR-305
No sound from surround speakers
you have it set in stereo mode change listen sound to auto this way whatever way the signal is coming thru you will hear it
Jan 09, 2009 | Kenwood VR-405 Receiver
Surround sound speakers
two rms-70 watt are good enough for you.
Jul 16, 2008 | Audio Players & Recorders
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
41 people viewed this question
 Grubhead
Grubhead
