Question about Toys
How can I disaassemble a Little Tikes climber cube?
I have a Little Tikes cube climber with slide that I can't seem to disassemble. The pieces just won't budge. Little Tikes suggested dish soap at the connecting places, but this has not worked.
4 Suggested Answers
SOURCE: Disassembly of Little Tikes Wave Slide playground
Hi there! On putting together my daughter's hide and slide (not having ordered it or seen it before) followed the instructions and managed to put the bottom step inside the frame instead of outside. Of course other half only noticed it once I had put the top step in - so to take it apart you will need the following:
Two long heavy duty flat bladed screw drivers and a lot of muscle!
First take the top platform on one side and disengage the two tabs on one side. Then insert one of the srewdrivers under the red locking tab and push up - the plastic will distort however, returns to original shape with judicious use of a heavy hammer. You will need to use the second screwdriver to disengage the clip in the tab and then twist the platform out of the frame to release the second. Repeat for the other side. The bottom platform is a just a reversal of the installation to release. I haven't moved the slide but as this is a 'gravity' fix should release with a bit of 'persuasion'. As these things are not designed to be taken apart after assembly they are frustrating to take apart - but with a little flex and muscle it can be done. Hope this helps.
Simon
Posted on Aug 02, 2009
  • 16 Answers
SOURCE: We have a Little Tikes
If there is an identical nut attached to any other part of the equipment, remove it, and take it to your hardware store to see if they have a match, then put it back on after you find the new one.
Posted on Jun 03, 2011
  • 6 Answers
SOURCE: REPAIR LARGE CRACK IN THE PLASTIC OF LITTLE TYKES CLIMBER
You call them up and you COMPLAIN. You tell them that you just bought this item in the last 6 mos. and the store will not take it back. Talk to a supv. if you have to. THEN they will tell you to take a permament marker and write a # they give you on the item, take a pic, email to them, and then call them back up and you should be able to 'order' any item of the same value you paid thru their online c/s. We had a Cozy Coupe car from 2003 that the parent handle swiveled and didn't hold firm. I called them up in 2005, sorry, had to lie and say I had just bought it that year, and they had me do what I explained, and then I purchased a $60 toy box from them and I did not pay for S&H. Good luck! I've always told people they back their products, regardless of how old they are! And honestly, that's what I thought with climbers, etc. They should really offer you a replacement. Now if none of this works, EPOXY glue always works great! And brace with something? Just bring the broken piece into Home Depot. :)
Posted on May 31, 2009
I need a replacement slide for the small Little Tikes climbing cube It was pink
Little Tikes has a pretty good support program. You can get parts here:
http://www.littletikes.com/replacement-parent/icat/replacementparent
Dec 02, 2014 | Little Tikes Toys
Little Tikes Replacement Parts
Sorry we do not have parts here.
Aug 22, 2017 | Little Tikes Toys
We have a Little Tikes sports climber (the one with a slide, goal and basketball/netball hoop. We have lost the nut that fixes the basketball hoop to the climber. Any suggestions please?
Jun 02, 2011 | Little Tikes Swing Along Castle
I bought an older four sided little tikes climber cube with slide and need help putting slide on!
I might be little late in replying ur query.. u might have even figured it by now.. But this is for the future reference.. here is the assembly instruction of cube climber with slide
http://www.littletikes.com/pdf/4969_4589.pdf
Jun 01, 2011 | Toys
Have a Little Tikes Endless Adventures Mountain Climber. The brown platform has cracked and has a hole in it now. I would like to replace this part.
Regards, Tony
May 17, 2011 | Little Tikes Endless Adventures Look Out...
The key is that one side/side combination must be done 1st then the others are easy. On ours I think it is the yellow/orange combination. Just try all the combinations. One works pretty easily, the others do not. We struggles too until we found the right combination. good lluck
Jul 09, 2009 | Toys
May 30, 2009 | Little Tikes Climb and Slide Castle
Need Instructions
I also needed them. I downloaded them from the Little Tikes website: http://www.littletikes.com/toys/jungle-climber.aspx
Apr 28, 2009 | Computers & Internet
Your 4 screws may hold the swing piece to the slide piece. You actually secure it to the slide side wall with one of the red screw caps but you can also secure it with 4 screws that screw into the plastic.  You can also find the manual and assembly instructions at littletikes.com
Mar 04, 2009 | Little Tikes Swing Along Castle
How to dismantle little tikes junior activity cube
At the opposite side to the slide you should see 4 dimples, these should have screws in them, possibly behind a plastic cap.
Take these out, flip the cube onto its side, holding the sides, push (or kick or use the mallet) to get the end piece moving, (there is a dimple which locates into the side which makes this difficult)
Once one side is out, the middle bits should come out easily.
The front (slide part) is assembled the same way.
Hope this helps.
May 05, 2008 | Baby Gear
Toys Logo
1,882 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
