I have a mitsubishi projection tv. when i turn it on it automatically turns off. what do i do
If the television gets too hot it will turn off while it's hot or won't turn back on until it cools down. Other wise your timer is probably on.
Posted on Jul 19, 2009
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS-60607 60inch projection TV, cannot turn on
Push input and menu buttons on the TV and hold them both in together for 5 seconds to see if it flashes a code. The let me know
Posted on Feb 22, 2008
IrishDruid
  • 2712 Answers
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Posted on Oct 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
Posted on May 22, 2009
SD Tech
  • 14553 Answers
SOURCE: TV won't turn on.
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Posted on Dec 28, 2009
Testimonial: "SD tech, I pushed the menu and device buttons and received the 2,2 code.....what's next?"
Mitsubishi ws 65907
do u hear a clicking sound.
this can be due to relays getting tripped
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
