Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Got spool out but don't know how to restring it (ryobi electric)
3 Suggested Answers
  • 3 Answers
SOURCE: How do I restring my Ryobi weed wacker
Start in the center ,snap the center in place. than put the ends out through the holes.
Posted on Jul 20, 2009
rycgl
  • 1545 Answers
SOURCE: I broke th pull cord
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Posted on Sep 22, 2010
How to restring trimmr line of ryobi gas trimmer
What is the model of your Ryobi trimmer? If it is a bump an cut, you just turn the big plastic screw on the bottom CCW, and take the spool off.
Oct 09, 2014 | Garden
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Restring stihl fe55
easy spool head or not??? your owners manual has directions.
Sep 02, 2012 | Stihl Fe 35,40,55 & Ec70 Electric...
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
I can't get both sides of my weedeater restring right so it can pop out when i hit i t on the ground
Make sure you are winding the string in the correct direction. Check the spool for arrows, as centrifugal force is what feeds the string out the holes.
Aug 29, 2011 | Ryobi Garden
How to get off the head so I can restring it
Unscrew the bump knob by holding the string head. Then, depress and twist the string spool and it will come right out.
Oct 05, 2010 | Ryobi Garden
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
125 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
