My air conditioner digital thermostat has gone blank screen. It is Carrier thermostat, and I see a number on the thermostat, 997-9708210-3. I can't tell how the thermostat is affixed to the wall, but I can open the door and all there is a big electronic plate. Is there a work around for a hot weekend, until thermostat can be repaired/replaced?
  • drp01 Jul 18, 2009
    I suspect there might be batteries in there somewhere, but all I see opening door is an electronic plate. Any thoughts on how it connects to wall? Can't see any screws, perhaps double sided tape. I hate to force it loose not knowing.
  • drp01 Jul 19, 2009
    I finally figured out how to get the thermo off the wall. YOu just pull the electronic plate out, and interior screws attached. I hooked blue to white wire, as there is no battery. Nothing happened.
  • 8,220 Answers
Get the front off and you will see the screws holding the control panel. The .3 amp fuse will be samwhiched between the board and the display panel.
Posted on Jul 19, 2009
  • 3,600 Answers
Hook up the blue wire to the whit bypass's the temp sender, but try replacing the batteries first K?
Posted on Jul 18, 2009
  • Bruce Hathcock Jul 19, 2009
    the plate is operated by batteries and wires one se t of wires calls the ac ito play this is normally blue and white, but if the batteries are out replace then to call in the thermal relay or you will not have cool air. I can tell you idf you look for the murecy vapor switsh and hook the one wire from one enfd to the other yo will get cold air, this bu passes the thermo switch butthe best thing to do is go to any place like diamond or any shop you can buy a new thermsotate and replace it for wire by wire color, this will make it work, if the thermal switch does not turn on the a then the fan is defective ry running colsd water o it to get it to cool, if that does not help then try to find where it is cold and hotand this will be your plugged spot causing the unit not to heat, try running cold water over it to ge *** to warm, and be sure to replace both fuses and kick the ac switch off and then on. if it does not coll your i over your head and need an expert ok?
My Carrier Home Central Air Conditioning Model Number 38CKC036 340 fan out side the house is not working it gives oout a low humming sound and fan doesnt rotate Serial Number 4698E05846 Manufacturer...
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 11, 2010 | Carrier 38CKC036 Air Conditioner
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
Blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Carrier thermidistat screen went blank
Check the battery in the thermostat it is dead!! Should be 2 AA batterys!
Sep 11, 2009 | Carrier Heating & Cooling
Blank Thermastat LCD
check power to the furnace.
Aug 10, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
