Question about Akai Televison & Video
The set is only showing vertical color lines. The sound is ok - j the picture is not showing.
  • sharon_mixon Jul 19, 2009
    BBE SRS
    Serial Number 5001702841
    Model Number PDP4206EM
    3-4 years old
  • 3,037 Answers
Well, either the ribbon cable running to the display panel is faulty or the panel itself. Usually it is the panel itself on Plamas which you can imagine isn't cheap to fix or replace. If it is still under warranty, great! If not, find a repair shop that will replace it for you if you don't have any electronic expertise. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
  • 3,230 Answers
First of all i like to know the make and model number of your TV. so i can help you in right way...
Also tell me how old is your TV?
Thanks
Posted on Jul 19, 2009
  • Mukesh Kumar Jul 19, 2009
    Well, problem seems in the Main board of your TV, need to check for bad capacitor.....
5 Suggested Answers
ProMonkey
  • 59 Answers
SOURCE: no picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
Posted on Mar 10, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
muntejaya
  • 10421 Answers
SOURCE: screen shows narrow vertical color lines across
You have problem with the Tcon. Please check it and get repaired or replaced. Check also the audio circuit. Regards
Posted on Jan 31, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Samsung HD TV no picture sound is ok only
This is an indication of faulty T-con board(LCD Controller board).
First, the unit needs to check for loose connection from this board and the mainboard. The cable must be pull-out, inspect and then re-insert and ensure that they are properly seat-in. If the symptoms still persist, you have to replace the T-con board.
If you can't troubleshoot the unit yourself, I would advice you to seek for an assistance of a qualified TV Technician to isolate the problem.
Hope helped you.
Have a nice day!
Thanks for using Fixya.
Also, check if the unit is still under warranty period, avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Posted on Jul 25, 2011
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
HL-6187W, picture has vertical lines
If you can post a picture of what the lines are I can assist with the possible causes. I would assume digital board or DMD/ light engine
But a pic would help make it easier to figure out whats going on with the set.Respond to this same post for assistance.
Aug 07, 2012 | Samsung HL-S6187W 61 in. HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Vertical lines on one half the screen
Sounds like Light engine sizzle noise makes me think color wheel.
Nov 18, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Televison & Video Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
