Bunn AXIOM  AXIOM-15-3 (38700.0000) Logo
Tina Gaines Posted on Oct 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I calibrate my coffee machine? I have a axiom 15-3
I have already taken panel off... no help
Kelley Hopper
Level 2:
  • Expert 67 Answers
  • Posted on Oct 02, 2016
Kelley Hopper
Expert
Level 2:
Answers
67
Questions
0
Helped
33895
Points
172
The programming is done on the front of the machine. Here's a link to the Service Manual. https://catalog.bunn.com/public/docs/41154.0000/E17/00/000/41154.0000.pdf
Model Axiom-DV-3-1L/2U PF (S&D), fills pot a little over half,how do you calibrate to fill up full
If it has been in service for awhile it probably is lime build up beyond the spray head. Unplug it turn water supply and off and take the top off so you can see the water tank.take the syphon tube off. That's probably all plunged up?
Dec 31, 2014 • Bunn AXIOM3
We have a Axiom 12 cup automatic. We have been having issues with the hot water spiket dripping. Any ideas why and how to fix? Thanks
u mean dripping on the water outlet on top of ur server ? ur dripping solenoid plunger might be already open a bit or ur incoming solenoid valve not closng properly
Hot water faucet adjustment?
The Axiom uses a water level probe to keep the heater tank filled with water at a set level. The hot water facet takes water directly from the top of the tank. It's gravity fed with only the weight of the top portion of the water (the hottest area) to flow into the faucet. It is possible that your faucet 'Boot' or spring is bad and needs replacement. But it's designed to give you a single cup of hot water. Do not expect to fill a pot (or large french press) with this faucet.
* Call your vendor for service.
Aloha, ukeboy57
(the parts manual) https://catalog.bunn.com/public/docs/39131.0000/E17/01/000/39131.0000.pdf
1helpful
How do i adjust the water level on my Axiom Bunn coffee maker? It only brews about a half of a pot.
Remove the front panel there are instructions on increasing the water level.
How do i calibrate my bunn machine?
Check the board on the machine there is a set lever on the right side and instructions on setting on the front cover panel.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
