Question about Cell Phones
Code for internet for unlocked cect
I need codes for the internet for an unlocked cect. The carrier is T-mobile
What is my phone restriction code of Nokia C3-00.1?
A Nokia C3 unlocked mobile phone works on all GSM networks. The Nokia C3 needs a Nokia unlock code in order to remove the SIM lock that comes on most SIM based cell phones by default. If your Nokia C3 has a SIM lock on it, then it will prevent you from using the mobile phone with any other carriers.I would first recommend you try getting a Nokia C3 unlock code by calling up your current phone carrier. In exchange, they will need your Nokia C3?s IMEI number. Your IMEI number is unique to your mobile device and the Nokia unlock code will be calculated using it. You can get the IMEI number on your Nokia C3 simply by typing *#06# and hitting the enter or send button. If you do not currently have a carrier or cannot get a free unlock code, then I would reccomend trying some of the unlock code websites that I have reviewed below.
Once you have your unlock code, you can begin the Nokia C3 unlocking steps below.
How To Unlock A Nokia C3 (SIM Unlock)1. Power ON your Nokia mobile phone without your SIM card.
2. Now type: #PW+CODE+1# (Where CODE is your Nokia unlock code)
3. Your phone should now show "SIM Restriction Off" and is unlocked.
Note: You must press the * key several times to get the characters for 'P' and 'W'.
If you would like to learn more about the Nokia C3 cell phone, then try reviewing some of the other related reviews below. Enjoy!
Note: The free unlock instructions provided on this site only work with GSM or SIM card versions of the Nokia C3. As always there may be already unlocked versions of this mobile phone, but generally cost a lot more then unlocking it yourself.
Getting a free code from your carrier doesn't always work
So try this unlock service HERE
If it does not support ur phone - then try this WEBSITE HERE
Feb 17, 2011 | NokiaFree Unlock Codes Calculator
How can i data unlock my cect iphone
CECT phones are always unlocked. However, your particular CECT phone may use different frequncies than what your cell carrier uses.
Think of if this way, your CECT phone works like a FM radio. Your phone might use 800mhz for making phone calls, and 2100Mhz for surfing the internet. But your carrier (T-Mobile, Orange, AT&T, etc) might using 800Mhz for phone calls and 1900Mhz for surfing the internet. If this is the case, you will not be able to use that phone on that carrier for data. Sorry.
Mar 05, 2010 | Dual Electronics CECT P168 Cellular Phone
Wap settings for i9++
UNLOCK INTERNET CODE FOR HAPPYDAYS I9 168 3G MOBILE PHONE
Dec 27, 2009 | Dual Electronics CECT P168 Cellular Phone
Need subsidy code for aircel, packed mobile
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Dual Electronics CECT P168 Cellular Phone
I NEED HELP REPAIRING MY I9 SCREEN
There are basically two ways to do this. You can get online to the Java website via your WAP browser and enter in the code for the CECT installation ((wap.GetJar.com and then quick the download code 30827.) I usually download via USB though as this puts a copy onto my computer (in case it accidentally gets deleted) and it doesn?t cost any money or data to do this. For the Java installation, go to the get jar website. Make sure that you have the device set to CECT A100 (the CECT default.) Connect the phone to the computer via USB. Hit the mass storage icon on the phone. Click on the jar file that you want to download. Click save. Next, find the drive that your phone is listed under. (For me, this is K:/, but it may be something different in your case.) Click OK. Then, unhook the phone from the USB. Go into the document icon on the phone. Find the received file and then scroll down until you see the browser and click it. Then click ?install.? Now, you?ll go into Java icon. You?ll see the browser in the list of Java files. Then click launch. Opera should launch and you can start browsing. Most often, when something goes wrong here, it?s because the data, WAP or Java settings aren?t correct. You?ll need to go in and set them up depending upon your carrier. For example, if you use T Mobile, you?ll need to input the T Mobile WAP, port, and data settings. Typically, you set the data first, then the GPRS, the WAP, and the MMS. Finally, go into the JAVA settings and make sure that T Mobile (or AT&T, or which ever carrier that you are using) is reflected. There are many resources that will give you the Internet settings for almost every applicable carrier that you can think of. If for some reason you can?t get online, I?d check to make sure the phone isn?t set to the original Chinese or factory settings. To view video, close up photos, full specifications, and real time rock bottom pricing on the CECT i9 please check out http://i9clonephonereview.com/ If you need a USB cord for the i9 (or other accessories including internet, MMS, or WAP set up instructions, cases and skins, unlimited data sim cards, memory cards, batteries, etc,) please visit http://i9accessories.com
Jun 15, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Im having trouble getting my internet and mms messages to work on my cect i68
i9forum.com tells you detailed how to program your phone for each different carrier
Apr 05, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Unlock code for cect p168+
Unlock code for CECT mobiles is : 0000
Aug 28, 2008 | Dual Electronics CECT P168 Cellular Phone
GPRS activation
Contact your current carrier for setting to use a different a carriers phone on their network. This will set up mobile internet and picture messaging. You may also want t confirm you have the correct service center number programmed in the phone.
You may also need and unlock code if you dont already have one. This can be obtained from the original carrier or through countless websites.If you choose to use a website please be careful. If the wrong unlock code is entered too many times your phone will permanently lock to the original carrier.
Feb 04, 2008 | Motorola Mobility A630
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
